cgal-discuss - Re: [cgal-discuss] Adding new "cgal" code to cgal 4.13
  • To:
  • Subject: Re: [cgal-discuss] Adding new "cgal" code to cgal 4.13
  • Date: Mon, 28 Jan 2019 09:17:29 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
You can use the master branch of CGAL:
https://github.com/CGAL/cgal/
Check out the doc for how to use a checkout of CGAL here:
https://github.com/CGAL/cgal/blob/master/INSTALL.md
Sebastien.
On 01/28/2019 05:22 AM, Dr01TSPC wrote:
I located (web search) a CGAL program that is of interest:
manifoldness_repair_example.cpp.
The url at which I found the program indicates that it will be in 4.14.
I found the program on github, under Polygon_mesh_processing.
I copied the code into my CGAL4.13/examples/Polygon_mesh_processing
directory. After some
trial and error and manual editing, I am pretty sure I got a legitimate
"build list" that includes
the above program.
The program does not compile, because (at least)
"is_non_manifold_vertex" is not a member of PMP.
and
"output_iterator" is not a member of NP.
I assume that is due to "membership changes" between 4.13 and 4.14.
Is there a recommended way to use such code?
Would downloading a more recent copy of 4.13 work?
Is 4.14 ready to install and test?
(And I hope install would be like installing a release version.)
Thanks,
Tim
