- To:
- Subject: Re: [cgal-discuss] Adding new "cgal" code to cgal 4.13
- Date: Mon, 28 Jan 2019 09:46:13 -0600 (CST)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
- Ironport-phdr: 9a23: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
Mael:
I think any/my attempt at cherry picking would lead to issues with using
other
programs in 4.13 (polygon and mesh), so I would build a separate
installation
in any case.
I will look into using the main branch on github. It will be a learning
experience.
Thanks,
Tim
- [cgal-discuss] Adding new "cgal" code to cgal 4.13, Dr01TSPC, 01/28/2019
- Re: [cgal-discuss] Adding new "cgal" code to cgal 4.13, Sebastien Loriot (GeometryFactory), 01/28/2019
- Re: [cgal-discuss] Adding new "cgal" code to cgal 4.13, Dr01TSPC, 01/28/2019
- Re: [cgal-discuss] Adding new "cgal" code to cgal 4.13, Mael, 01/28/2019
