- To:
- Subject: Re: [cgal-discuss] meshing tool
- Date: Fri, 22 Feb 2019 10:46:20 -0600 (CST)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
- Ironport-phdr: 9a23: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
Hi all,
Does this question have any updated answer? A criteria that defines by
sizing_function instead of the default two constants.
Thank you.
- Re: [cgal-discuss] meshing tool, Yixuan Li, 02/22/2019
