cgal-discuss - [cgal-discuss] How does CGAL mesh isosurfaces defined as gray levels in 3D images?
  • To:
  • Subject: [cgal-discuss] How does CGAL mesh isosurfaces defined as gray levels in 3D images?
  • Date: Sat, 23 Feb 2019 10:11:24 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Importance: normal
  • Ironport-phdr: 9a23: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
  • Sensitivity: Normal
Hello everyone,
I'm using CGAL to mesh isosurfaces defined as gray levels in 3D images. It produces nice results. However, I don't have a clue how the underlying algorithm works. Can someone explain to me on a high-level what the algorithm does?
The cited paper "Jean-Daniel Boissonnat and Steve Oudot. Provably good sampling and meshing of surfaces. Graphical Models, 67:405–451, 2005." goes to much into detail. I can not really follow it, due to missing background.
Kind regards
Jacky
