- To: "" <>
- Subject: Re: [cgal-discuss] Add vertex info before inserting constraints
- Date: Fri, 12 Apr 2019 17:01:59 +0000
- Accept-language: en-CA, en-US
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=Pass
- Ironport-phdr: 9a23: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
insert_constraint takes 2 points or vertex handles, and sets an edge between the two to be a constraint.
These constraint vertexes will exist in the triangulation, so just insert them as normal, and obtain a handle to them.
// these will be your constraints
Vertex_handle vh = cdt.insert(Point(x,y)); // can insert with info or whatever
Vertex_handle vh1 = cdt.insert(Point(x1,y1));
and then you can insert the constraint
cdt.insert_constraint(vh,vh1);
I do it this way as I'm reading in points from a file. I'm unsure how you obtain the vertex handles if you use the .begin(), .end() insertion approach you showed. But this should get you started at least.
Cheers
Chris
Hi,
I am using the Constrained_Delaunay_triangulation_2 class. I want to attach
vertex info to the constraint vertices before calling insert_constraint, in
the same way as I can add info to vertices before inserting in a
triangulation. I cannot find a CGAL method to do this. Here's my code
#include <CGAL\Exact_predicates_inexact_constructions_kernel.h>
#include <CGAL/Constrained_Delaunay_triangulation_2.h>
#include <CGAL/Triangulation_vertex_base_with_info_2.h>
#include <vector>
class VertexInfo
public:
double data;
int index;
VertexInfo() {}
VertexInfo(double e, int i)
:data(e), index(i) {}
typedef CGAL::Exact_predicates_inexact_constructions_kernel
Kernel;
typedef CGAL::Exact_predicates_tag Itag;
typedef CGAL::Triangulation_vertex_base_with_info_2<VertexInfo, Kernel> Vb;
typedef CGAL::Constrained_triangulation_face_base_2<Kernel> Fb;
typedef CGAL::Triangulation_data_structure_2<Vb, Fb>
Tds;
typedef CGAL::Constrained_Delaunay_triangulation_2<Kernel, Tds, Itag>
Delaunay;
typedef Kernel::Point_2
CGAL_Point;
int main()
Delaunay T;
std::vector< std::pair<CGAL_Point, VertexInfo> > points;
points.push_back(std::make_pair(CGAL_Point(0.123456789, 0), VertexInfo(0.3,
-1)));
points.push_back(std::make_pair(CGAL_Point(1, 0), VertexInfo(0.5, -1)));
points.push_back(std::make_pair(CGAL_Point(0, 1), VertexInfo(1.3, -1)));
points.push_back(std::make_pair(CGAL_Point(1, 1), VertexInfo(0.8, -1)));
points.push_back(std::make_pair(CGAL_Point(2, 2), VertexInfo(0.3, -1)));
// Triangulate
T.insert(points.begin(), points.end());
std::vector< std::pair<CGAL_Point, VertexInfo> > constraintPts;
constraintPts.push_back(std::make_pair(CGAL_Point(10, 10), VertexInfo(1.3,
0)));
// how do I add constraints with vertex just like above?
T.insert_constraint(constraintPts.begin(), constraintPts.end()); // this
gives a compiler error
return 0;
If this is not possible, I would like to get the vertex handles of the
constrained vertices and then attach the vertex info to each vertex. Is this
possible?
- [cgal-discuss] Add vertex info before inserting constraints, malcolm, 04/12/2019
- Re: [cgal-discuss] Add vertex info before inserting constraints, Marsh, Chris, 04/12/2019
- Re: [cgal-discuss] Add vertex info before inserting constraints, malcolm, 04/15/2019
