- To:
- Subject: Re: [cgal-discuss] Add vertex info before inserting constraints
- Date: Mon, 15 Apr 2019 02:02:41 -0500 (CDT)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Fail ; spf=Pass
- Ironport-phdr: 9a23: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
Thanks Chris. I think this will do in the present situation. I will have to
separately insert each pair of points from the polyline constraint, get the
handles and attach the vertex info.
Ideally, I am looking to insert the info for all the points at once. Doens't
seem to be possible with the current API.
- [cgal-discuss] Add vertex info before inserting constraints, malcolm, 04/12/2019
- Re: [cgal-discuss] Add vertex info before inserting constraints, Marsh, Chris, 04/12/2019
- Re: [cgal-discuss] Add vertex info before inserting constraints, malcolm, 04/15/2019
