- To:
- Subject: Re: [cgal-discuss] Segmentation Fault/Having Trouble Running Polyhedron_3 Demo
- Date: Fri, 10 May 2019 11:09:04 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
From the message you're showing, it seems that some opengl part are not
implemented in wine. I guess you should try to compile the CGAL demo
yourself and target MacOs natively.
Sebastien.
On 5/4/19 7:03 PM, sfucci wrote:
Using a Mac, trying to run Polyhedron_3.exe with wine,
Enable scripts.
002d:fixme:wgl:set_pixel_format DC for window 0x10062 of other process: not
implemented
002d:fixme:win:EnumDisplayDevicesW ((null),0,0x22dfd8,0x00000000), stub!
002d:fixme:wgl:set_pixel_format DC for window 0x30066 of other process: not
implemented
002d:fixme:wgl:set_pixel_format DC for window 0x40066 of other process: not
implemented
002d:fixme:wgl:set_pixel_format DC for window 0x50066 of other process: not
implemented
Execution of script ":/cgal/Polyhedron_3/javascript/lib.js"
002d:fixme:wgl:set_pixel_format DC for window 0x60066 of other process: not
implemented
In CGAL_handle_signal, Program received signal SIGSEGV: Segmentation
Fault.wc132-dhcp-137:polyhedron_3 sonya1$
Not sure what to do here, or if anyone else has experienced this. Thanks!
- [cgal-discuss] Segmentation Fault/Having Trouble Running Polyhedron_3 Demo, sfucci, 05/04/2019
- Re: [cgal-discuss] Segmentation Fault/Having Trouble Running Polyhedron_3 Demo, Sebastien Loriot (GeometryFactory), 05/10/2019
