- To:
- Subject: Re: [cgal-discuss] I cannot run the straight skeleton example
- Date: Fri, 10 May 2019 06:05:40 -0500 (CDT)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Fail ; spf=Pass
- Ironport-phdr: 9a23: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
Hi,
the example is self-contained, it does not ask for input. Taking the
Create_offset_polygons_2 project, the polygon used in the main file
(Create_offset_polygons_2.cpp) is the one I posted below.
Best regards,
Jann
poly.push_back( Point(-1,-1) ) ;
poly.push_back( Point(0,-12) ) ;
poly.push_back( Point(1,-1) ) ;
poly.push_back( Point(12,0) ) ;
poly.push_back( Point(1,1) ) ;
poly.push_back( Point(0,12) ) ;
poly.push_back( Point(-1,1) ) ;
poly.push_back( Point(-12,0) ) ;
- [cgal-discuss] I cannot run the straight skeleton example, jpmaterial, 05/08/2019
- Re: [cgal-discuss] I cannot run the straight skeleton example, Sebastien Loriot (GeometryFactory), 05/10/2019
- Re: [cgal-discuss] I cannot run the straight skeleton example, jpmaterial, 05/10/2019
- Re: [cgal-discuss] I cannot run the straight skeleton example, Sebastien Loriot (GeometryFactory), 05/15/2019
- Re: [cgal-discuss] I cannot run the straight skeleton example, jpmaterial, 05/16/2019
