cgal-discuss - Re: [cgal-discuss] Mesh only corefined after applying clipping function
  • To:
  • Subject: Re: [cgal-discuss] Mesh only corefined after applying clipping function
  • Date: Mon, 13 May 2019 05:02:20 -0500 (CDT)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Neutral ; spf=Pass
  • Ironport-phdr: 9a23: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
I was able to solve this problem by slightly modifying the input file.
However I am now struggling to save the clipped mesh. I would like the
clipped mesh to be open, so I called PMP::clip(tm, clipper, false);
The clipping seems to work, the number of vertices changes from 18 to 414.
But when I try to save the clipped mesh in an OFF file, the output file
contains only the header without any vertices and faces. I did not change
anything else. When I keep the clipped mesh closed, I get a valid output
file. What am I missing?
cuboid.off
<http://cgal-discuss.949826.n4.nabble.com/file/t376108/cuboid.off>
patch.off <http://cgal-discuss.949826.n4.nabble.com/file/t376108/patch.off>
