Re: [cgal-discuss] Get the texture coordinates after intersection--nef_polyhedron
- To:
- Subject: Re: [cgal-discuss] Get the texture coordinates after intersection--nef_polyhedron
- Date: Tue, 14 May 2019 02:09:49 -0500 (CDT)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Fail ; spf=Pass
- Ironport-phdr: 9a23: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
Hi Sebastien:
i find your reply there and i meet the same question as this. i wonder if
there is any way that i can get the intersection of two mesh M1 and M2,
among which M1 is sef-intersection an not closed, M2 is a simple mesh.
i have tried many ways. as servicebbs metioned, i use "3D boolean operations
on nef polyhedra" but the mesh have to be closed. then i use the
"Polygon_mesh_processing" to do the clip, but the mesh cannot be
self-intersection. so i want to know if there is any way in cgal that can
deal with the mesh that is unclosed and sef-intersection when wie do the
intersection.
thank you very much!
- Re: [cgal-discuss] Get the texture coordinates after intersection--nef_polyhedron, Environment, 05/14/2019
