cgal-discuss - Re: [cgal-discuss] Polyhedron constructor
  • To:
  • Subject: Re: [cgal-discuss] Polyhedron constructor
  • Date: Fri, 24 May 2019 09:31:46 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
polygon_soup_to_polygon_mesh() should be doing what you want:
https://doc.cgal.org/latest/Polygon_mesh_processing/group__PMP__repairing__grp.html#gac8fe80db9800265922ce469c36d97baa
Sebastien.
On 5/17/19 10:36 PM, rahulverma88 wrote:
Hi,
Are there any examples showing construction of a polyhedron from a list of
vertices? From the CGAL documentation, I can only find an example which
reads in an OFF file to get that list of vertices
(https://doc.cgal.org/latest/Polyhedron/Polyhedron_2draw_polyhedron_8cpp-example.html#a2).
I'm also new to computational geometry. Is it perhaps not possible to
construct a general polyhedron from a list of vertices? And I have to list
edges, facets etc?
-Rahul
