- To:
- Subject: Re: [cgal-discuss] Offset of surface
- Date: Mon, 10 Jun 2019 10:34:28 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
What kind of surface do you have? Are sharp feature important?
If not, you could mesh the offset surface as an implicit function.
For example in this plugin:
https://github.com/CGAL/cgal/blob/master/Polyhedron/demo/Polyhedron/Plugins/Surface_mesh/Offset_meshing_plugin.cpp
we mesh the general offset of a triangle mesh.
Sebastien.
On 6/10/19 10:06 AM, Hy.Joe wrote:
Hi, is it possible to give a different offset by a direction? For example 2mm
in z direction, 0.5mm in x, y direction. Any idea to solve this problem
using CGAL or another library?
- [cgal-discuss] Offset of surface, Hy.Joe, 06/10/2019
- Re: [cgal-discuss] Offset of surface, Sebastien Loriot (GeometryFactory), 06/10/2019
