cgal-discuss - [cgal-discuss] Polyhedron_incremental_builder_3 still asserts after a rollback
  • To:
  • Subject: [cgal-discuss] Polyhedron_incremental_builder_3 still asserts after a rollback
  • Date: Tue, 11 Jun 2019 17:15:41 -0500 (CDT)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Neutral ; spf=Pass
  • Ironport-phdr: 9a23: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
I added a facet using builder.begin_facet(). I saw that it was bad, and I
performed a rollback. Still, the destructor of the builder asserted on
CGAL_destructor_assertion(check_protocoll == 0)
How can I prevent the assertion?
A more general question. From what I read on assertion, you can either
enable all of them or disable all of them (with a compiler directive).
There's no temporary disable/enable. I should probably convert the behavior
to throw instead of assert, although the link on this post isn't valid
anymore?
http://cgal-discuss.949826.n4.nabble.com/Precondition-fail-assert-instead-of-throw-td4662414.html
  • [cgal-discuss] Polyhedron_incremental_builder_3 still asserts after a rollback, Zohar, 06/12/2019
