- To:
- Subject: [cgal-discuss] A bit of help with the Quadratic Programming solver
- Date: Wed, 12 Jun 2019 02:25:39 +0300
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Hi everyone,
This is the first time I'm using CGAL's QP solver and I ran into an issue where I don't get the expected result in a very simple scenario.
I put everything on a document so it's easier for you to check it out (including minimal source code). The document is here: https://www.docdroid.net/jEFGEEt/cgal-qp.pdf (I didn't want to attach it, as I don't know if that's allowed)
If someone could take a quick look at it and help me out I will greatly appreciate it. It may be something very trivial that I missed.
Thank you all and best regards,
Alex.
- [cgal-discuss] A bit of help with the Quadratic Programming solver, Al Mo, 06/12/2019
- Re: [cgal-discuss] A bit of help with the Quadratic Programming solver, Mael, 06/17/2019
- Re: [cgal-discuss] A bit of help with the Quadratic Programming solver, Marc Glisse, 06/17/2019
- Re: [cgal-discuss] A bit of help with the Quadratic Programming solver, Al Mo, 06/17/2019
