- To:
- Subject: Re: [cgal-discuss] Find all neighbours of a certain primitive
- Date: Fri, 14 Jun 2019 08:19:25 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23: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
Hello, When you mean "vertex", do you mean a combinatorial vertex, or do
you mean its geometric position? What is supposed to be done in
non-manifold situations such as two independent umbrellas around
the same (combinatorial) vertex? What do you mean with
Face_around_target "failed"? Where are your colors coming from? Note that if you are interested in defining connected components on your mesh, you can also look into these functions. The null face represents the outside of the domain, and is just usually a null pointer which is why it is so silent (but something else could be done it's true). You can check if your face is this null face via an equality check with "boost::graph_traits<Graph>::null_face()", and if you are manipulating (half)edges via the "is_border(h/e, g)". Best, On 13/06/2019 17:02, Rash wrote:
It works, thank you a lot. There is a small bug. I would like to find all neighbours, not only the ones which share a edge. If two triangles share a vertex (but not an edge), they should be neighbours. Here is an example (same color means it is a connected surface). There should be only a red and one green surface. There are 4 surfaces colors. https://owncloud.ev-bs.de/index.php/s/1qFVNbiwA2Z6o7D I tried to use: CGAL::Face_around_target_circulator< Graph > but I failed. Is there a way to get all triangles which share a vertex descriptor with surface mesh? For finding one connected Surface I wrote this code. What could I change to get all connected faces, even the one only connected via a single vertex? My code: void visitAllFaces(const face_descriptor &_fd, std::map<face_descriptor,size_t> &_maps, std::set<face_descriptor> &_visited, const size_t _patch_index, const Mesh& _mesh) { const size_t key_was_found = _visited.count(_fd); if(!key_was_found) { _visited.insert(_fd); _maps[_fd] = _patch_index; for(face_descriptor neigh_fd : CGAL::faces_around_face(halfedge(_fd, _mesh), _mesh)) // m is your surface mesh { if(neigh_fd != boost::graph_traits<CGAL::Surface_mesh<K::Point_3> >::null_face()) { visitAllFaces(neigh_fd,_maps,_visited, _patch_index,_mesh); } } } } Btw. having null faces which just crash (no assert warning) is realy confusing. Am 16.05.19 um 08:22 schrieb Mael: Hello, Do you really care for the primitive, or just the neighboring faces? If you just want the neighboring faces, and assuming your primitive is AABB_face_graph_triangle_primitive, the primitive ID is a boost::graph_traits<Surface_mesh>::face_descriptor (i.e. Surface_mesh::Face_index) and you can use BGL-like functions provided by CGAL such as CGAL::faces_around_face <https://doc.cgal.org/latest/BGL/group__PkgBGLIterators.html#ga5a12f39e74a0667374570d61b859bfb1>: face_descriptor fd = p_id; for(face_descriptor neigh_fd : CGAL::faces_around_face(halfedge(fd, sm), sm) // sm is your surface mesh { etc } See the package BGL <https://doc.cgal.org/latest/BGL/group__PkgBGLRef.html> for a lot of convenient functions (it requires a data structure to fit a certain interface, which CGAL::Surface_mesh does using the 'graph_traits' interface). Best, Mael On 16/05/2019 01:57, Rash wrote:Hi people, I wrote a small raytracer (with CGAL::Surface_mesh<Point> Mesh) with tree acceleration in cgal. I would like to find all neighbours of a hit primitive. Ray_intersection hit = tree.first_intersection(rays[y][x]); if(hit) { const Point& point = boost::get<Point>(hit->first); const Primitive_id& primitive_id = boost::get<Primitive_id>(hit->second); //i need the neighbours of the hit primitive } How do I this? I found this documentation but it seems to work only for points not primitives: https://doc.cgal.org/latest/Spatial_searching/index.html And it searches for its euclidan distance not for being connected together. Is there something like: std::vector<Primitive_id&> ids = getNeighoursOfPrimive(primitive_id); Like I said I am using CGAL::Surface_mesh<Point> Mesh for my mesh and their is only one mesh in the scene. Kind regards Rashid |
- Re: [cgal-discuss] Find all neighbours of a certain primitive, Rash, 06/13/2019
- Re: [cgal-discuss] Find all neighbours of a certain primitive, Mael, 06/14/2019
