cgal-discuss - [cgal-discuss] Bump, see other issue
  • To:
  • Subject: [cgal-discuss] Bump, see other issue
  • Date: Sun, 16 Jun 2019 16:06:19 +0300
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
Hi,
I recently raised an issue, you can see it here: http://cgal-discuss.949826.n4.nabble.com/A-bit-of-help-with-the-Quadratic-Programming-solver-td4664269.html
I would like to ask someone to help me with that. The solution may actually be a trivial thing, but maybe it's an experience that helps the platform grow.
As a token of gratitude I can tell you that I've been on the other side and plenty of times I had helped a lot of people with the time and dedication they deserve.
* If you are more driven by money, I understand and is fine for me as well, you can quote me whatever you may seem appropriate for your attention to this. *
Thanks everyone!
Alex.
  • [cgal-discuss] Bump, see other issue, Al Mo, 06/16/2019
