cgal-discuss - Re: [cgal-discuss] Find boundary cells of C3t3 mesh
  • To:
  • Subject: Re: [cgal-discuss] Find boundary cells of C3t3 mesh
  • Date: Thu, 22 Aug 2019 12:16:43 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
  • Ironport-phdr: 9a23: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
Hello,
you can find all the info you need by using directly the triangulation stored in the C3t3's data structure.
You can iterate on the C3t3 cells as you did with
`for (Cell_iterator it = grid.cells_in_complex_begin(); it !=grid.cells_in_complex_end(); ++it)`
Then, for each cell, you can iterate on its 4 facets (see [1], Facet is pair<Cell_handle, int>). For each facet, use `c3t3.is_in_complex(f)` (see [2]) to check whether the facet is of interest for you.
Then, the function `mirror_facet(f)` [3] gives you the facet seen from the adjacent cell, on the "other side" of the facet. So you have all info about both cells adjacent to the complex facet.
Hope it helps!
Jane.
Jane Tournois, PhD
R&D Engineer at GeometryFactory
http://www.geometryfactory.com/
[1] https://doc.cgal.org/latest/TDS_3/classTriangulationDataStructure__3.html#ad6a20b45e66dfb690bfcdb8438e9fcae
[2] https://doc.cgal.org/latest/Mesh_3/classMeshComplex__3InTriangulation__3.html#a34e31b26c5578ab03a212f21e3ad703b
[3] https://doc.cgal.org/latest/TDS_3/classTriangulationDataStructure__3.html#af386d55822ab1d47703f4500d642a7f2
Le 19/08/2019 à 22:50, Valentin Boltach a écrit :
Good afternoon!
I ran into a little problem: Is there any interface for getting information
about the boundary cells of the figure's mesh?
CGAL has functions that can retrieve all information about boundary vertices
and faces but there's no info about cells.
I've tried one in some case incorrect variant, but it also doesn't work for
non-convex figure:
*0. We create a map from the vertices in the form of a key and the vertex
number as a value
typedef typename Tr::Point Point_3;
std::map<Point_3, int> V;
Tr t = grid.triangulation();
int k = 0;
for (Tr::All_vertices_iterator it = t.all_vertices_begin(); it !=
t.all_vertices_end(); ++it) {
if (k == 0) {
k++;
continue;
V[it->point()] = k;
++k;
*1. We get a vector of all boundary faces (thanks to the method for output
mesh in .off format)
C3t3::Subdomain_index sd_index = 0;
bool normals_point_outside_of_the_subdomain = false;
typedef std::vector<std::size_t> Face;
std::vector<Point_3> points;
std::vector<Face> faces;
CGAL::Mesh_3::internal::facets_in_complex_3_to_triangle_soup(grid,
sd_index, points, faces,
normals_point_outside_of_the_subdomain);
*2. We form a list of all possible surfaces for each cell and form a map,
the key of which are 3 vertices of the face, and the key is the vector of
cell numbers.
std::map<std::set&lt;int>, vector<int>> cellNodes;
typedef typename C3t3::Cell_iterator Cell_iterator;
ofstream myfile;
int k = 1;
int facesPositions[4][3] = {{0,1,2}, {1,2,3}, {0,1,3}, {0,2,3}};
grid.cells_in_complex_end(); ++it) {
const Tr::Cell c(*it);
for(int i = 0; i < 4; i++) {
std::set<int> enodes;
enodes.clear();
for(int j = 0; j < 3; j++) {
enodes.insert(V[c.vertex(facesPositions[i][j])->point()]);
cellNodes[enodes].push_back(k);
k++;
*3. We iterate over all complex faces. If there is a match, then print the
number of the cell found
size_t elemNumber = 0;
typedef typename Tr::Cell_handle
Cell_handle;
typedef typename Tr::Vertex_handle
Vertex_handle;
typedef typename Tr::Weighted_point
Weighted_point;
typedef CGAL::Hash_handles_with_or_without_timestamps
Hash_fct;
typedef boost::unordered_map<Vertex_handle, std::size_t, Hash_fct>
VHmap;
typedef typename C3t3::Facets_in_complex_iterator
Ficit;
VHmap vh_to_ids;
std::size_t inum = 0;
for(Ficit fit = grid.facets_in_complex_begin(),
end = grid.facets_in_complex_end(); fit != end; ++fit)
Cell_handle c = fit->first;
int s = fit->second;
Face f;
CGAL::Mesh_3::internal::resize(f, 3);
typename C3t3::Subdomain_index cell_sdi = grid.subdomain_index(c);
typename C3t3::Subdomain_index opp_sdi =
grid.subdomain_index(c->neighbor(s));
if(cell_sdi != sd_index && opp_sdi != sd_index)
continue;
for(std::size_t i=1; i<4; ++i)
bool is_new;
typename VHmap::iterator map_entry;
Vertex_handle v = c->vertex((s+i)&3);
enodes.insert(V[v->point()]);
CGAL_assertion(v != Vertex_handle() &&
!grid.triangulation().is_infinite(v));
boost::tie(map_entry, is_new) =
vh_to_ids.insert(std::make_pair(v, inum));
if(is_new)
++inum;
f[i-1] = map_entry->second;
if(((cell_sdi == sd_index) == (s%2 == 1)) ==
std::swap(f[0], f[1]);
const std::size_t fs = f.size();
if(cellNodes.find(enodes) == cellNodes.end()) {
LOG(INFO) << "NOT FOUND! " << enodes;
else {
std::vector<int> elementsNumbers = cellNodes[enodes];
LOG(INFO) << "Found! Cell#" << elementsNumbers.front();
The problem is that Cell_handle contains information about *only 3 of its
vertices, not 4*, that's why I have to come up with options for iterating
over faces. How to be in this situation?
