cgal-discuss - Re: [cgal-discuss] Find boundary cells of C3t3 mesh
  • To:
  • Subject: Re: [cgal-discuss] Find boundary cells of C3t3 mesh
  • Date: Mon, 26 Aug 2019 14:26:16 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
  • Ironport-phdr: 9a23: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
Hi,
for each `Cell_handle c`, and i an integer between 0 and 3, Facet(c, i) is the ith facet of c, seen from inside c. So you only need to iterate on i.
All the data structure is explained in the Triangulation_data_structure_3 documentation :
https://doc.cgal.org/latest/TDS_3/classTriangulationDataStructure__3.html
Le 23/08/2019 à 22:54, Valentin Boltach a écrit :
Hi,
Thanks a lot for this answer. I understood everything except iteration on
facets.
Because i'm new in cgal, it's quite difficult to understand all interfaces
Can you describe this moment in detail?
Jane Tournois, PhD
R&D Engineer at GeometryFactory
http://www.geometryfactory.com/
