- To:
- Subject: Re: [cgal-discuss] Multi-domain mesh generation with sharp edges
- Date: Mon, 26 Aug 2019 14:29:58 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23: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
Hello,
Le 26/08/2019 à 07:42, imperin a écrit :
Hello Jane,
1.I tried to adapt the hybrid domain example , and did what you said , but I
can use detect_features only inside struct for
Polyhedral_mesh_domain_with_features_3, and nothing happens when i do it.
right, you need to adapt your Hybdrid mesh domain so that it is able to detect once and only once each feature polyline.
2. I also tried Polyhedral_complex_mesh_domain_3, but I need to make pairs
of surfaces i do not know the numbers. Is there automatic tool for finding
intersecting surfaces of multiple Polyhedrons?
I don't think we have an automatic tool for that. You can use AABB_tree to detect collisions between polyhedra, and then put it together with the info you have (like knowing that polyhedra do not intersect but are adjacent, etc)
Thanks a lot.
Jane Tournois, PhD
R&D Engineer at GeometryFactory
http://www.geometryfactory.com/
- [cgal-discuss] Multi-domain mesh generation with sharp edges, imperin, 08/20/2019
- Re: [cgal-discuss] Multi-domain mesh generation with sharp edges, Jane Tournois, 08/22/2019
- Re: [cgal-discuss] Multi-domain mesh generation with sharp edges, imperin, 08/22/2019
- Re: [cgal-discuss] Multi-domain mesh generation with sharp edges, Jane Tournois, 08/23/2019
- Re: [cgal-discuss] Multi-domain mesh generation with sharp edges, imperin, 08/26/2019
- Re: [cgal-discuss] Multi-domain mesh generation with sharp edges, Jane Tournois, 08/26/2019
- Re: [cgal-discuss] Multi-domain mesh generation with sharp edges, Sebastien Loriot (GeometryFactory), 08/26/2019
