cgal-discuss - Re: [cgal-discuss] Problem with element size.
  • To:
  • Subject: Re: [cgal-discuss] Problem with element size.
  • Date: Mon, 9 Sep 2019 06:48:51 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
The picture is small and I have no idea what is the input model.
Several possible cause for small elements:
- Feature not correctly detected
- the domain has a small local feature size:
-- 2 sheets close together
-- one feature close to a sheet
Sebastien.
On 9/6/19 9:43 AM, imperin wrote:
I use detect_features() for the domain, but the output result is not so
good(See pic.1).
Mesh_domain domain(block1);
domain.detect_features();
Mesh_criteria criteria(edge_size = 0.005,
facet_angle = 30, facet_size = 0.005, facet_distance = 0.00000005,
cell_radius_edge_ratio = 2, cell_size = 0.005);
// Mesh generation
C3t3 c3t3 = CGAL::make_mesh_3<C3t3>(domain, criteria, lloyd(time_limit=3),
odt(time_limit=3),
perturb(time_limit=30, sliver_bound=30), exude(time_limit=30,
sliver_bound=30));
