cgal-discuss - Re: [cgal-discuss] How can I fetch the label value of a mesh vertices?
  • To:
  • Subject: Re: [cgal-discuss] How can I fetch the label value of a mesh vertices?
  • Date: Sun, 8 Sep 2019 23:56:01 -0500 (CDT)
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
  • Ironport-phdr: 9a23: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
But the voxel label value information is already in the triangular mesh. When
I generated the triangular surface mesh from the 3D image, I already kept
the vertex material information in the surface mesh. Now I just need to
fetch the material information. Do I again need to add property?
Regards
Shrabani
