cgal-discuss - Re: [cgal-discuss] 3d mesh outwards offsetting
  • To:
  • Subject: Re: [cgal-discuss] 3d mesh outwards offsetting
  • Date: Fri, 20 Sep 2019 10:24:20 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
There is a plugin in the Polyhedron demo that allows you to mesh the offset surface of a given input mesh. The quality of the result depends
on the input criteria. It will generate a non-self-intersecting surface
but sharp feature that should be in the output mesh will not be present.
It handle positive and negative offsets.
The code of the plugin is here:
https://github.com/CGAL/cgal/blob/master/Polyhedron/demo/Polyhedron/Plugins/Surface_mesh/Offset_meshing_plugin.cpp
Sebastien.
On 9/12/19 2:20 PM, aseverino wrote:
Hello. I've been playing around with CGAL for just over a year now and
recently I came across the need of creating an offset of a Surface_mesh.
Couldn't find anything conclusive in the CGAL documentation.
My problem is simple. My only concern is the concave vertices that shall not
self-intersect. Sharp features being rounded or even entirely lost is
actually a desired result, but not required.
Any thoughts?
