Re: [cgal-discuss] Is it possible create c3t3 mesh without changing anything in the criterion?
- To:
- Subject: Re: [cgal-discuss] Is it possible create c3t3 mesh without changing anything in the criterion?
- Date: Wed, 02 Oct 2019 09:37:53 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=None
- Ironport-phdr: 9a23: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
On Wednesday, October 2, 2019 1:12:06 AM CEST Shrabani Ghosh wrote:
> Hi,
> I am trying this example
> https://doc.cgal.org/latest/Mesh_3/Mesh_3_2mesh_polyhedral_domain_8cpp-examp
> le.html Is it possible to keep the same mesh and make it in c3t3 without
> changing anything in the criterion.
> Means the input and output mesh will be the same mesh?
That example shows that one can call `CGAL::make_mesh_3` to create the c3t3,
and then change it with a call to `CGAL::refine_mesh_3`. But the second call
is completely optional. Most of the applications will never refine a mesh
once
it is created. The example is just a demonstration that it is possible.
Laurent Rineau, PhD
- [cgal-discuss] Is it possible create c3t3 mesh without changing anything in the criterion?, Shrabani Ghosh, 10/02/2019
- Re: [cgal-discuss] Is it possible create c3t3 mesh without changing anything in the criterion?, Laurent Rineau (CGAL/GeometryFactory), 10/02/2019
- Re: [cgal-discuss] Is it possible create c3t3 mesh without changing anything in the criterion?, Shrabani Ghosh, 10/02/2019
