cgal-discuss - Re: [cgal-discuss] Is it possible create c3t3 mesh without changing anything in the criterion?
  • To:
  • Subject: Re: [cgal-discuss] Is it possible create c3t3 mesh without changing anything in the criterion?
  • Date: Wed, 2 Oct 2019 10:11:08 -0500 (CDT)
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
  • Ironport-phdr: 9a23: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
Thank you for your response. But, in the criteria the parameters change the
mesh even I don't use refine. Like in the picture. the left one is the c3t3
mesh after using the criteria. And the right is the original eight.off file.
<http://cgal-discuss.949826.n4.nabble.com/file/t376134/35.png>
Is that possible to make no change in the criteria?
Is it possible to ignore it?
CGAL::Mesh_criteria_3< Tr >::Mesh_criteria_3 ( Field1
parameters::edge_size
= ignored,
FT parameters::facet_angle = ignored,
Field2 parameters::facet_size = ignored,
Field3 parameters::facet_distance = ignored,
Mesh_facet_topology parameters::facet_topology =
CGAL::FACET_VERTICES_ON_SURFACE,
FT parameters::cell_radius_edge_ratio = ignored,
Field4 parameters::cell_size = ignored
I tried something this but it does not work.
Thank You.
