- To:
- Subject: Re: [cgal-discuss] Stitch polylines onto surface mesh
- Date: Fri, 4 Oct 2019 15:56:10 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:SITXeRNEhAT0Ur/0vlQl6mtUPXoX/o7sNwtQ0KIMzox0I/z9rarrMEGX3/hxlliBBdydt6sfzbeP+P66EUU7or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6arXK99yMdFQviPgRpOOv1BpTSj8Oq3Oyu5pHfeQpFiCezbL9oLBi6sArdu8gIjYB/Nqs/1xzFr2dSde9L321oP1WTnxj95se04pFu9jlbtuwi+cBdT6j0Zrw0QrNEAjsoNWA1/9DrugLYTQST/HscU34ZnQRODgPY8Rz1RJbxsi/9tupgxCmXOND9QL4oVTi+6apgVRnlgzoFOTEk6mHaktF+grxVoByhpBJxzYDbb46XO/Vica3QZs8aSGhbU8pNSyBMDIGxYo0SBOQBJ+ZYqIz9qkMAoRWjGwajH/ngyiRUhn/3w6I61fkqHwfB3Aw6HtIOt2jUp8jxOKkTT++1y6zIwivfb/NM2Tbz6JLHfQw9ofGLR7Jxcc/dxUcyHA7ClVWQrYvlPymU1uQKr2iX9e9gVea0hm4orgF+uDmvxsM2hobVgYIVz0nJ+CNky4g7It24TVR0Yd+iEJZIsSGVLZB5TdgmQ252oio11roGuZu9cSMXy5on3wbSZ+Kbf4WM+B7uV+acLS1miH57Zb6znRm//Ei4xuHiTMa4zEtGoy9bndTCuX0A0gLc6saGR/Rh+0qtxDmC2BvP5uxBP087iaTbJpAkz7M+ipUcqkvOEyrql0rrgq+aakAp9vWn5unkbLjroIKXOZVuhQHkKKsun9SyAeQmPQgKWGiW4eG826fi/U39WblLgOc2nrTAvJDUKskWprS1AwBS0oYk5Ba/Cymp3M4EknkAKVJJYBOHj473NFHSOP30E+uzjlC2nDpox/3KJKPtDovQInTZn7rsfa5x60tGxwoyydBf6YhUCrYEIP/rQU/xsNvYDgU4Mwyz3+brEtB91ocFVGKAB6+WKqLSsVuS6u0zJOmMYZcZuCzhJPg9+/7ukXg5lEcBcqmmx5QXbGm0EelnI0WCfXXsn8wBEXwRswolTO3qjUWCXiRJa3azWaI8/DA7B5i8AYfNXID+yICGiSy0F5kTamFdAU2XCl/pcZ+FUrECcnG8OMhkx3Y/WLKoUJMg2BfmkAjgyr17Zqr79yoduI75xfZ87PHUjwBzv3QgFMCayWCKUydxmksHQjY32OZ0pkkrmQTL6rRxn/ENTY8b3PhOSApvbceAndw/MMj7X0f6RvnMUEyvG4z0DjQ4T9Z3yNgLMR4kSoeSyyvb1i/vOIc70rmCBZg66KXZhiGjKMN0ynKA364k3QB/H5l/cFa+j6s6zDD9Qo7El0LDyvSvfKUYmTHXrSKNkTfIs0ZfXwp9F67CWCJHaw==
Since all the points lie on a plane, there is another way to do it.
Create a surface mesh and use add_face() with your range of points.
Then call PMP::triangulate_faces()
It should be faster (using a 2D triangulation instead of a 3D one
basically).
Sebastien.
On 10/4/19 3:52 PM, aseverino wrote:
It was the triangulate_hole_polyline
Thank you so much!
- [cgal-discuss] Stitch polylines onto surface mesh, aseverino, 10/04/2019
- Re: [cgal-discuss] Stitch polylines onto surface mesh, Sebastien Loriot (GeometryFactory), 10/04/2019
- Re: [cgal-discuss] Stitch polylines onto surface mesh, aseverino, 10/04/2019
