[cgal-discuss] Significantly inflated executable size using later CGAL libraries
- To:
- Subject: [cgal-discuss] Significantly inflated executable size using later CGAL libraries
- Date: Mon, 7 Oct 2019 19:12:08 -0400
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
hi everyone,
As some of you know, in my matlab meshing toolbox (iso2mesh), I embedded a few modified CGAL demo utilities. In the past, these utilities were statically compiled and distributed along with my toolbox. I saw there was a push to migrate to the newer CGAL releases (https://github.com/fangq/iso2mesh/issues/12#issuecomment-468601734), so last year, I had added the compilation scripts (https://github.com/fangq/iso2mesh/tree/master/tools) to compile these tools and link with the newer versions of CGAL, but noticed one problem: the binaries compiled/linked using the newer CGAL libraries (~4.10 or newer) are dramatically (5x to 10x) larger than the older libraries (3.8-4.2).
I got even more surprised as I started packaging iso2mesh for Fedora over the past few days
https://bugzilla.redhat.com/show_bug.cgi?id=1758626
the binaries generated on CGAL 4.14/Fedora 30 are even bigger than I've seen before - the 3D mesher code (cgalmesh) grows to 67MB compared to 4.5MB using CGAL 3.8 (15x), and mesh_polyhedral mesher (cgalpoly) example produced a 90 MB executable compared to 4.3 MB previously.
I am wondering if there is a way (a link/compile flag?) that I can reduce the binary size? loading a large executable is quite inefficient because disk reading is very slow compared to execution. I could use an exe packers, such as upx, to compress the exe by about 9-fold, but they are still several fold larger than what they used to be (after packing).
let me know if you have any suggestions, thanks
Qianqian
- [cgal-discuss] Significantly inflated executable size using later CGAL libraries, Qianqian Fang, 10/08/2019
- Re: [cgal-discuss] Significantly inflated executable size using later CGAL libraries, Laurent Rineau (CGAL/GeometryFactory), 10/10/2019
