Re: [cgal-discuss] Significantly inflated executable size using later CGAL libraries
- To:
- Subject: Re: [cgal-discuss] Significantly inflated executable size using later CGAL libraries
- Date: Thu, 10 Oct 2019 18:43:14 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=None
- Ironport-phdr: 9a23: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
On Tuesday, October 8, 2019 1:12:08 AM CEST Qianqian Fang wrote:
> the binaries generated on CGAL 4.14/Fedora 30 are even bigger than I've
> seen before - the 3D mesher code (cgalmesh) grows to 67MB compared to
> 4.5MB using CGAL 3.8 (15x), and mesh_polyhedral mesher (cgalpoly)
> example produced a 90 MB executable compared to 4.3 MB previously.
As discussed with Qianqian Fang on the Fedora bug tracker [1], the binaries
were compiled with debug symbols. Once stripped,
- cgalpoly is 2.7MB,
- cgalmesh is 2.0MB.
That looks like even smaller than the numbers announced with CGAL-3.8.
[1]: https://bugzilla.redhat.com/show_bug.cgi?id=1758626
Laurent Rineau, PhD
- [cgal-discuss] Significantly inflated executable size using later CGAL libraries, Qianqian Fang, 10/08/2019
- Re: [cgal-discuss] Significantly inflated executable size using later CGAL libraries, Laurent Rineau (CGAL/GeometryFactory), 10/10/2019
