cgal-discuss - [cgal-discuss] Is it possible to keep track of edges are collapsing in surface mesh?
  • To:
  • Subject: [cgal-discuss] Is it possible to keep track of edges are collapsing in surface mesh?
  • Date: Thu, 10 Oct 2019 22:57:27 -0500 (CDT)
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
  • Ironport-phdr: 9a23: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
Hi,
I am working on surface_mesh_simplification.
I am referencing here this example.
https://doc.cgal.org/latest/Surface_mesh_simplification/Surface_mesh_simplification_2edge_collapse_visitor_surface_mesh_8cpp-example.html
I want to keep track of the edges are collapsing for further use.
Let's say, in my mesh, there are 10 edges.
I want to use keep trace if edges 5,6,7,8 are collapsing.
if 6 and 7 number edges are collapsed, I want to save the edge numbers.
And after collapsing edges on the first iteration, the ids of the edges
changes from the original mesh?
Thank you.
Shrabani Ghosh
