cgal-discuss - Re: [cgal-discuss] Is it possible to keep track of edges are collapsing in surface mesh?
  • To:
  • Subject: Re: [cgal-discuss] Is it possible to keep track of edges are collapsing in surface mesh?
  • Date: Thu, 17 Oct 2019 08:30:12 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
If you assigned your ids like you shown, then the number printed in the
visitor should be the same.
If not there must be some issue in your code as no new halfedge is
created by the simplification package.
Sebastien.
On 10/17/19 4:18 AM, Shrabani Ghosh wrote:
Hi,
I assigned id to the halfedges. Like this :
  for( Surface_mesh::Halfedge_iterator eb = surface_mesh.halfedges_begin()
     , ee = surface_mesh.halfedges_end()
     ; eb != ee
     ; ++ eb
    eb->id() = index++;
But in the visitor, it does not print the original edges ids but just prints the increment numbers. How can I print in the visitor so that it shows the edge->id and I want to see the sequence of edge collapse?
Edges collected: 23
Edges collapsed: 1
Edges collapsed: 2
Edges collapsed: 3
Edges collapsed: 4
Edges collapsed: 5
Edges collapsed: 6
Edges collapsed: 7
Edges collapsed: 8
Edges collapsed: 9
Edges non_collapsable: 1
Edges non_collapsable: 2
Edges non_collapsable: 3
Edges collected: 23
Edges processed: 12
Edges collapsed: 9
Edges not collapsed due to topological constraints: 3
Edge not collapsed due to cost computation constraints: 0
Edge not collapsed due to placement computation constraints: 0
Finished...
20 edges removed.
6 final  half edges.
These are the final halfedges ids.
28
29
32
33
36
37
Thank You
Shrabani Ghosh
On Wed, Oct 16, 2019 at 3:10 AM Sebastien Loriot (GeometryFactory) < <mailto:>> wrote:
You have the information about what will be collapsed in the visitor.
You are free to assign an id to the edge if needed using a hash map
if needed.
Sebastien.
On 10/11/19 5:57 AM, Shrabani Ghosh wrote:
> Hi,
> I am working on surface_mesh_simplification.
> I am referencing here this example.
https://doc.cgal.org/latest/Surface_mesh_simplification/Surface_mesh_simplification_2edge_collapse_visitor_surface_mesh_8cpp-example.html
> I want to keep track of the edges are collapsing for further use.
> Let's say, in my mesh, there are 10 edges.
> I want to use keep trace if edges 5,6,7,8 are collapsing.
> if 6 and 7 number edges are collapsed, I want to save the edge
numbers.
> And after collapsing edges on the first iteration, the ids of the
edges
> changes from the original mesh?
> Thank you.
> Shrabani Ghosh
> Sent from: http://cgal-discuss.949826.n4.nabble.com/
-- You are currently subscribed to cgal-discuss.
