- To:
- Subject: [cgal-discuss] Midpoint subdivision for triangle meshes
- Date: Tue, 15 Oct 2019 10:23:25 -0500 (CDT)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
- Ironport-phdr: 9a23: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
I am looking for a way to perform midpoint subdivision on a triangular mesh.
The basic idea is that I want to do Loop subdivision without interpolating
the new vertices. Is this implemented somewhere? I was looking at the
`ptq_1step` function here
<https://github.com/CGAL/cgal/blob/master/Subdivision_method_3/include/CGAL/Subdivision_method_3/internal/subdivision_hosts_impl_3.h#L181>
, but it seems to use internal capabilities that are not exposed through the
API. Additionally, I don't need any sort of mask. What would the best way to
go about implementing this be?
- [cgal-discuss] Midpoint subdivision for triangle meshes, meder411, 10/15/2019
- Re: [cgal-discuss] Midpoint subdivision for triangle meshes, Mael, 10/16/2019
- Re: [cgal-discuss] Midpoint subdivision for triangle meshes, Marc Eder, 10/17/2019
