cgal-discuss - Re: [cgal-discuss] Midpoint subdivision for triangle meshes
  • To:
  • Subject: Re: [cgal-discuss] Midpoint subdivision for triangle meshes
  • Date: Wed, 16 Oct 2019 08:54:58 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=None ; spf=None
  • Ironport-phdr: 9a23:PFbYxBxzo8upIDvXCy+O+j09IxM/srCxBDY+r6Qd2+MWIJqq85mqBkHD//Il1AaPAdyAra0YwLOP6ejJYi8p2d65qncMcZhBBVcuqP49uEgeOvODElDxN/XwbiY3T4xoXV5h+GynYwAOQJ6tL1LdrWev4jEMBx7xKRR6JvjvGo7Vks+7y/2+94fcbglVijexe7F/IRq5oQnMq8Uan5ZpJ7osxBfOvnZGYfldy3lyJVKUkRb858Ow84Bm/i9Npf8v9NNOXLvjcaggQrNWEDopM2Yu5M32rhbDVheA5mEdUmoNjBVFBRXO4QzgUZfwtiv6sfd92DWfMMbrQ704RSiu4qF2QxLulSwJNSM28HvPh8JtkqxbrhKvqR9xzYHab46aNuZxcKzGcNMGR2dMRNpdWzBPD46+aYYEEuoPPfxfr4n4v1YAqgGxCheoBOjyzTJIg2X50rM+0+g7CwHG2xEgHt0Qv3TQttn1ML0dXvuuw6bW1jjDYO1Z2TD46IfWbhAhu/GNXbxqfsXN1UkvEBnFj1WKpYP5ODOV0/0Avm6G5ORuUuKvjnQoqwB3ojW3wMcjkJLGiZkRyl/a7yl23IE1JdigREFnbt6rCp9QuzudN4tsTcMuW25ouCcmyr0GpJ60ZzIGx4ggxx7abfGMbouG4gr7WeueIDp0nm9pdK6/ihqo80Wty/fwWtS03VpWtiZJjMPAum0N2hDJ98SKRflw8l2/1TqT0w3e7PxPL1oumqrBMZEhx6Y9lpoNvkTHGS/7gFj6gLOMekUh/eik9ubqb7b8qp+ZLYB0iwX+Pr0pmsyiHeQ0KA8OX3ab+eim0r3s41H5TK1Ljv0wjKbZrIjXKMsaq6KjHgNZzoYu5wy9AjqnytgUgHkKIE5ddBKClYfpOlXOIP7iDfe4hlShiDJryOrYMb3lGJnNNH/DkKrufLlj705Q0g4zwspE6J1PFL4MO/3zVVH2tNzdEBA5Lxa0wubpCNpnyoweRWWPArWZMa/IrVCI4ecvL/GWZIAJoDb9N+Ql5/n2gHAlll8SZ62p0YIKZ3C5BfRpP1iZYWH3gtoaCmcLvg8+TPTwh1GYUD5TYWyyX6Mm6T0hBoKmF9SLeof4i7OI2GK3H4Zde3tdIlGKC3bhMYueCNkWbyfHB8ZslnRQULGsT8k70gy+uQu8z7NtJOf89SAfsJ//zsl77ubPkgsjszdzCpLOgCm2U2hokzZQFHcN16dlrBklkwbR4e1Dm/VdUOdrybZMWwY+O4TbyrYjWd//XQfMYs2YRl+tXtK8EHc6Sddjm4ZTMXY4IM2ri1X45wTvA7IRkObUVsVstKfbhiehYcN0ynKD07Q9yV44Qo1JOHH03vcjpTiWPJbAlgCir4jvbb4Vhnef+2qEyGeSplBWWQVsVr/UG3sYYxmOoA==
Hello,
Have you looked at the following example : https://doc.cgal.org/latest/Subdivision_method_3/Subdivision_method_3_2Customized_subdivision_8cpp-example.html ? You can customize your Loop subdivision's mask, e.g. to have vertices not moving and new subdividing points being middle of existing edges, which is what you wish to have if I understand correctly.
Best,
Mael
On 15/10/2019 17:23, meder411 wrote:
I am looking for a way to perform midpoint subdivision on a triangular mesh.
The basic idea is that I want to do Loop subdivision without interpolating
the new vertices. Is this implemented somewhere? I was looking at the
`ptq_1step` function here
<https://github.com/CGAL/cgal/blob/master/Subdivision_method_3/include/CGAL/Subdivision_method_3/internal/subdivision_hosts_impl_3.h#L181>
, but it seems to use internal capabilities that are not exposed through the
API. Additionally, I don't need any sort of mask. What would the best way to
go about implementing this be?
