cgal-discuss - Re: [cgal-discuss] Intersection of polyhedrons
  • To:
  • Subject: Re: [cgal-discuss] Intersection of polyhedrons
  • Date: Thu, 17 Oct 2019 01:49:36 -0500 (CDT)
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
  • Ironport-phdr: 9a23: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
Hi Sebastien,
Thank you a lot for your quick response.
I'm beginner in cgal.
I'll clarify my issue.
I have one big polyhedron_3 (> 1000 vertexes or more)
and many different small polyhedron_3's (like cube or brick, about 10
vertex )
I want to estimate a volume of intersection between big and one of small
polyhedron fast (ideally not more than 4-10 ms).
I don't need too much accuracy, only relative rating.
I saw this class
https://doc.cgal.org/latest/Polygon_mesh_processing/classCGAL_1_1Side__of__triangle__mesh.html.
But how do you propose using it? I mean, I can to check where is point
relative to the body, but if I will sort through a large number of points, I
think it will not be very effective.
