Re: [cgal-discuss] CGAL surface mesh simplification - how to get compact triangular faces?
- To:
- Subject: Re: [cgal-discuss] CGAL surface mesh simplification - how to get compact triangular faces?
- Date: Tue, 29 Oct 2019 07:26:45 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:YnKisx+21VzT1/9uRHKM819IXTAuvvDOBiVQ1KB20+McTK2v8tzYMVDF4r011RmVBN6dsqocwLuM+4nbGkU4qa6bt34DdJEeHzQksu4x2zIaPcieFEfgJ+TrZSFpVO5LVVti4m3peRMNQJW2aFLduGC94iAPERvjKwV1Ov71GonPhMiryuy+4ZLebxhGiTanfL9+MAm6oQrVu8UInIBvNrs/xhzVr3VSZu9Y33loJVWdnxb94se/4ptu+DlOtvwi6sBNT7z0c7w3QrJEAjsmNXs15NDwuhnYUQSP/HocXX4InRdOHgPI8Qv1Xpb1siv9q+p9xCyXNtD4QLwoRTiv6bpgRRn1gykFKjE56nnahNFugqJVoByvpBJxzIDbb46XKPVwcbjQfc8YSGdbQspdSyJMD4G6YoASD+QBJ+FYr4zlqlcAsBWxGxKjC/n0yj9Uh3/5w6s62PknHwHBxgwgHtUOsGjJp9nxNakdT+e1zKzWwjXfdfNX2Tfz55LUfRA9pvGMR7Jxfc/fxUIyEA7FlVGQqYv/PzOU0eQNr3KX7+9kVe+0hG4nrht+ojmrxss2lobJgYcVx0nC+C5kzog1Iti4R1R6Yd6iCJZQsTuVOJBtTcMmXW5kojo1yroDuZO9YSMEy4wnygbBZ/Cbd4WE+BHuWeaLLTtmmn5pZaizihm9/ES41OHzTNW43EtPoyVbnNTBuXUA2ALd6sWGVvRw+1qt1DmU2AzP7+xJI0Q5mKXYJpMkzLM/jJkevEDGEyDrhUn5l66be0A+9eWm6+nqbLPrrYKGOYBukAHxKKEul9S/AesmNggOWHCW+eGm273i+U31WbtLjucrnqXAvpDXKssWqrS2Aw9S1YYj5BK/ACm83NsEmnkHKUpJeBOBj4f3J1HDOO70Aeu7jli2kzpmx+rKMqP/DpnQNHTOn7jsca5460FGyQozyd5f54hTCrEEOP/zQUvxtNvCDh84NAy03/zrCNB51o4FVmKPB7WWMKLWsVOS+u0vJOyMaJcPuDnhM/gl++LujXghlFABcqmmx58XZGmlEfRnOEWWfWfsgswaEWoRpQo/TOnqiEWYXjJJZnayWbg85jAhB468A4fDXNPlvLvU1yiyGthaZ3tNF0uXOXbubYSNHfkWOwyIJco02AcJX7G6V44s01mKsxX7zKYvbsXZ/SgVqYjy+tF+++rJhFB4vWhvC8OH0maRCWRwtmwNTj4ymqt4pBoumR+4zaFkjqkARpRo7PRTX1JibMOO/6lBE9n3Hzn5UJKJRVKhGIj0BDgwSpcu2YZLbRohXdqliR/H0myhBLpHz+XaVqxxybrV2j3KH+g4zn/H0Kc7iFx/G5lAMGSnguh08A2BXteVwXXcrL6jcOEn5ACI7H2KlDPcs0RRUQo2WqLADygS
Could you show what is the input of the simplification algorithm and what is the output?
What stop criteria did you use? How did you constrain edges?
Sebastien.
On 10/28/19 8:01 PM, Shrabani Ghosh wrote:
Thank You Sebastien for your response.
I am attaching here a snapshot.
<http://cgal-discuss.949826.n4.nabble.com/file/t376134/Untitled.png>
Regards
Shrabani Ghosh
- [cgal-discuss] CGAL surface mesh simplification - how to get compact triangular faces?, Audette, Michel A., 10/25/2019
- Re: [cgal-discuss] CGAL surface mesh simplification - how to get compact triangular faces?, Sebastien Loriot (GeometryFactory), 10/28/2019
- Re: [cgal-discuss] CGAL surface mesh simplification - how to get compact triangular faces?, Shrabani Ghosh, 10/28/2019
- Re: [cgal-discuss] CGAL surface mesh simplification - how to get compact triangular faces?, Sebastien Loriot (GeometryFactory), 10/29/2019
- Re: [cgal-discuss] CGAL surface mesh simplification - how to get compact triangular faces?, Shrabani Ghosh, 10/29/2019
