- To:
- Subject: [cgal-discuss] 3D surface mesh generation of two implicit spheres
- Date: Mon, 28 Oct 2019 16:18:15 -0500 (CDT)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
- Ironport-phdr: 9a23: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
Hi all,
I want to be able to mesh 3d surfaces from an implicit function representing
several smooth closed surfaces.
From what I understand by reading the doc and a previous post
(http://cgal-discuss.949826.n4.nabble.com/About-the-surface-mesh-generator-td952799.html)
I need to add one initial sample point for each connected component to the
initial triangulation.
I did a test with two spheres (inspired from CGAL tests
@https://github.com/CGAL/cgal/blob/69fad29842b8a3a7316ea478b3a4da3a47d6bf6a/Surface_mesher/test/Surface_mesher/implicit_surface_mesher_test.cpp#L138),
but I can't get the final mesh with both the spheres in it.
<http://cgal-discuss.949826.n4.nabble.com/file/t376135/Capture.png>
Is there something else I need to do after adding the initial points to the
triangulation or am I doing something wrong?
Thanks for your help,
What I did (see code below):
1 . create two implicit spheres
- left -> center = (-4,0,0), radius = 2
- right -> center = (4, 0,0), radius = 2
2. Insert one seed point per sphere to the triangulation
- left -> seed = (-2,0,0);
- right -> seed = (2,0,0);
3. Mesh the implicit surface representing both spheres
4. Output mesh to .off file
#include <CGAL/Surface_mesh_default_triangulation_3.h>
#include <CGAL/Complex_2_in_triangulation_3.h>
#include <CGAL/make_surface_mesh.h>
#include <CGAL/Implicit_surface_3.h>
#include <CGAL/Polyhedron_3.h>
#include <CGAL/IO/facets_in_complex_2_to_triangle_mesh.h>
#include <string>
#include <iostream>
#include <fstream>
template <typename K>
class Sphere {
public:
typedef typename K::FT FT;
typedef typename K::Point_3 Point_3;
typedef typename K::Sphere_3 Sphere_3;
Sphere(Sphere_3 sphere)
: sphere(sphere)
FT operator()(const Point_3& p) const
FT x = p.x();
FT y = p.y();
FT z = p.z();
x-=sphere.center().x();
y-=sphere.center().y();
z-=sphere.center().z();
return x*x+y*y+z*z-sphere.squared_radius();
private:
const Sphere_3 sphere;
class TwoSpheres
public:
TwoSpheres(Sphere<K> sphere1, Sphere<K> sphere2)
: sphere1(sphere1), sphere2(sphere2)
return sphere1(p)*sphere2(p);
private:
const Sphere<K> sphere1;
const Sphere<K> sphere2;
// Aliases
using Kernel =
CGAL::Exact_predicates_inexact_constructions_kernel;
using Sphere_3 = Kernel::Sphere_3;
using Point_3 = Kernel::Point_3;
using FT = Kernel::FT;
using Tr = CGAL::Surface_mesh_default_triangulation_3;
using C2t3 = CGAL::Complex_2_in_triangulation_3
using Polyhedron = CGAL::Polyhedron_3<Kernel>;
using ImplicitSurface_3 = CGAL::Implicit_surface_3<Kernel,
TwoSpheres<Kernel>>;
int main() {
// Construct the spheres
// - left -> center = (-4,0,0), radius = 2
// - right -> center = (4, 0,0), radius = 2
const Sphere<Kernel> sphere_left (Sphere_3(Point_3(-4., 0., 0.), 4.));
const Sphere<Kernel> sphere_right(Sphere_3(Point_3(4., 0., 0.), 4.));
// Assemble the two spheres
const TwoSpheres<Kernel> two_spheres(sphere_left, sphere_right);
// Create the seeds for the 3D-Delaunay triangulation
// - one seed per connected component
const Point_3 point_left (-2,0,0);
const Point_3 point_right(2,0,0);
if(two_spheres(point_left) != 0)
std::cerr << "ERROR: Left seed is not on sphere!" << std::endl;
if(two_spheres(point_right) != 0)
std::cerr << "ERROR: Right seed is not on sphere!" << std::endl;
// Set the 3D-Delaunay triangulation
Tr tr;
tr.insert(point_left);
tr.insert(point_right);
// Set the 2D-complex in 3D-Delaunay triangulation
C2t3 c2t3 (tr);
// Define the implicit surface
const ImplicitSurface_3 surface(two_spheres,
Sphere_3(CGAL::ORIGIN,
100));
// Define meshing criteria
const CGAL::Surface_mesh_default_criteria_3
criteria(30., // angular bound
0.1, // radius bound
0.1); // distance bound
// Mesh surface
CGAL::make_surface_mesh(c2t3, surface, criteria,
CGAL::Non_manifold_tag());
std::cout << "Final number of points: " << tr.number_of_vertices() <<
std::endl;
// Converts to polyhedron
Polyhedron output_mesh;
CGAL::facets_in_complex_2_to_triangle_mesh(c2t3, output_mesh);
// Save to .off file
const std::string output_filename = "test.off";
std::cout << "Write file " << output_filename << std::endl;
std::ofstream out(output_filename.c_str());
out << output_mesh;
- [cgal-discuss] 3D surface mesh generation of two implicit spheres, Gaetan, 10/28/2019
- Re: [cgal-discuss] 3D surface mesh generation of two implicit spheres, Laurent Rineau (CGAL/GeometryFactory), 10/29/2019
- Re: [cgal-discuss] 3D surface mesh generation of two implicit spheres, Gaetan, 10/29/2019
