- To:
- Subject: Re: [cgal-discuss] 3D surface mesh generation of two implicit spheres
- Date: Tue, 29 Oct 2019 09:48:01 -0500 (CDT)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
- Ironport-phdr: 9a23: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
Hi Laurent,
Thanks for your prompt answer, I see your example works fine.
Therefore my next question: how can we know the minimum number of initial
points required per component?
Is it more related to the initial cells (one initial cell per component) or
is it something else?
- [cgal-discuss] 3D surface mesh generation of two implicit spheres, Gaetan, 10/28/2019
- Re: [cgal-discuss] 3D surface mesh generation of two implicit spheres, Laurent Rineau (CGAL/GeometryFactory), 10/29/2019
- Re: [cgal-discuss] 3D surface mesh generation of two implicit spheres, Gaetan, 10/29/2019
