- To:
- Subject: [cgal-discuss] CGAL- How to generate a adaptive sampling on surface?
- Date: Mon, 16 Dec 2019 07:02:23 -0600 (CST)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Fail ; spf=Pass
- Ironport-phdr: 9a23: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
Hi everyone~ I want to know how to get adaptive sampling on surface. The
'adaptive' means the samples on feature part can be more dense.
I have tried search about this. Yet I only get some surface reconstruction
method or mesh generation method have this effect. However, it is not
*sampling on the Original Surface*.
I just wonder if there exist some sampling method in CGAL. Or I didn't find
it without using a right name describing it.
Thanks for you kind help and guidance.
- [cgal-discuss] CGAL- How to generate a adaptive sampling on surface?, Frank Dz, 12/16/2019
- Re: [cgal-discuss] CGAL- How to generate a adaptive sampling on surface?, Sebastien Loriot (GeometryFactory), 12/16/2019
- Re: [cgal-discuss] CGAL- How to generate a adaptive sampling on surface?, Frank Dz, 12/16/2019
