- To:
- Subject: [cgal-discuss] Anisotropic mesh refinement
- Date: Sat, 14 Dec 2019 09:18:23 -0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Hi,
I need to refine a 2D triangular mesh in an anisotropic way.
Triangles end up with a high aspect ratio, following a fracture path.
Please see an example I made manually, without refinement.
I tried some pre-transformations + refine, but I could not get proper control of the CDT on a very deformed mesh.
Any idea?
Thanks,
Renato
- [cgal-discuss] Anisotropic mesh refinement, Renato Espírito Basso Poli, 12/14/2019
