- To:
- Subject: [cgal-discuss] Runnintime : polyhedron demo vs full cgal build
- Date: Fri, 10 Jan 2020 07:24:43 -0600 (CST)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
- Ironport-phdr: 9a23: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
Hello,
I have downloaded the Polyhedron Demo for Windows as well as the demo dlls
and I have tested some functionalities that it provides.
I have tested the same functionalities with my own code or with the
"examples" codes provided in the CGAL folder. I use CGAL as header-only,
build a .exe and run it via the command prompt.
It seems that the running time is significantly faster on the Polyhedron
Demo than with my own .exe. For instance, I have tested "Isotropic
Remeshing" on the same mesh with the same paremeters, it takes more than a
minute with my own .exe and seems to be done in less than a second with the
demo.
What could be the explanation for this difference ?
Thank you in advance !
Maxime
- [cgal-discuss] Runnintime : polyhedron demo vs full cgal build, Maxime Legraive, 01/10/2020
- Re: [cgal-discuss] Runnintime : polyhedron demo vs full cgal build, Sebastien Loriot (GeometryFactory), 01/10/2020
- Re: [cgal-discuss] Runnintime : polyhedron demo vs full cgal build, Maxime Legraive, 01/10/2020
