- To:
- Subject: Re: [cgal-discuss] Runnintime : polyhedron demo vs full cgal build
- Date: Fri, 10 Jan 2020 14:44:30 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Hello Maxime,
Could you share the program you are running?
Did you compile in release mode?
What compiler are you using?
Best regards,
Sebastien.
On 1/10/20 2:24 PM, Maxime Legraive wrote:
Hello,
I have downloaded the Polyhedron Demo for Windows as well as the demo dlls
and I have tested some functionalities that it provides.
I have tested the same functionalities with my own code or with the
"examples" codes provided in the CGAL folder. I use CGAL as header-only,
build a .exe and run it via the command prompt.
It seems that the running time is significantly faster on the Polyhedron
Demo than with my own .exe. For instance, I have tested "Isotropic
Remeshing" on the same mesh with the same paremeters, it takes more than a
minute with my own .exe and seems to be done in less than a second with the
demo.
What could be the explanation for this difference ?
Thank you in advance !
Maxime
- [cgal-discuss] Runnintime : polyhedron demo vs full cgal build, Maxime Legraive, 01/10/2020
- Re: [cgal-discuss] Runnintime : polyhedron demo vs full cgal build, Sebastien Loriot (GeometryFactory), 01/10/2020
- Re: [cgal-discuss] Runnintime : polyhedron demo vs full cgal build, Maxime Legraive, 01/10/2020
