cgal-discuss - [cgal-discuss] Unknown CMake command “create_single_source_cgal_program”
  • To:
  • Subject: [cgal-discuss] Unknown CMake command “create_single_source_cgal_program”
  • Date: Mon, 3 Feb 2020 23:37:54 -0600 (CST)
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
  • Ironport-phdr: 9a23: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
I have been trying to install CGAL on Ubuntu through a VirtualBox for a
while, every time I run the command - cmake -DCMAKE_BUILD_TYPE=Debug
-DCGAL_DIR=/cgal - on an example, I get the following message(with no other
errors):
CMake Error at CMakeLists.txt:12 (create_single_source_cgal_program):
Unknown CMake command "create_single_source_cgal_program".
-- Configuring incomplete, errors occurred!
See also
"/home/botengu/cgal/Bounding_volumes/examples/Min_sphere_d/CMakeFiles/CMakeOutput.log".
I have seen the other similar topics on the page, they either differed a bit
or they weren't answered. I'd like anyone to help solve this problem.
