- To:
- Subject: Re: [cgal-discuss] using cgal AABB tree as class member
- Date: Thu, 6 Feb 2020 09:28:00 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
the container `list<Triangle> triangles;` is local to the constructor
`AABBTree::AABBTree()` and you build the tree inside this function.
It means that when you go out of this function, the AABB-tree refers
to element in a container that has been deleted (when going out of the
scope of the constructor).
You should use CGAL::Exact_predicates_inexact_constructions_kernel instead of CGAL::Simple_cartesian<double>.
When posting code, you should use gist.github.com as it offers
syntax highlighting that ease the reading of the code.
Best,
Sebastien.
On 2/4/20 5:02 PM, myociss wrote:
*intersections.hpp:
#include <vector>
#include <list>
#include <array>
#include <iterator>
#include <functional>
#include <memory>
#include <Eigen/Dense>
#include <CGAL/Simple_cartesian.h>
#include <CGAL/AABB_tree.h>
#include <CGAL/AABB_traits.h>
#include <CGAL/AABB_triangle_primitive.h>
#ifndef INTERSECTIONS_HPP
#define INTERSECTIONS_HPP
using namespace std;
using namespace Eigen;
typedef CGAL::Simple_cartesian<double> K;
typedef K::FT FT;
//typedef K::Ray_3 Ray;
typedef K::Line_3 Line;
typedef K::Point_3 Point;
typedef K::Plane_3 Plane;
typedef K::Segment_3 Segment;
typedef K::Triangle_3 Triangle;
typedef list<Triangle>::iterator Iterator;
typedef CGAL::AABB_triangle_primitive<K, Iterator> Primitive;
typedef CGAL::AABB_traits<K, Primitive> AABB_triangle_traits;
typedef CGAL::AABB_tree<AABB_triangle_traits> Tree;
typedef Tree::Primitive_id Primitive_id;
class Intersection {
bool exists;
Vector3d point;
Vector3d normal;
vector<Vector3d> triangle;
public:
Intersection (bool _exists, Vector3d _point, Vector3d _normal,
vector<Vector3d> _triangle);
bool Exists();
Vector3d Point();
Vector3d Normal();
vector<Vector3d> Triangle();
class AABBTree {
shared_ptr<Tree> tree;
public:
AABBTree (vector<array<double, 3>> & _points, vector<array<int,
3>> & _tris,
Vector3d & p0, Vector3d & p1);
Intersection getIntersection(Vector3d & p0, Vector3d & p1,
vector<Vector3d> & _lastIntersected);
*intersections.cpp
#include <vector>
#include <list>
#include <array>
#include <iterator>
#include <future>
#include <iostream>
#include <thread>
#include <limits>
#include <boost/optional.hpp>
#include "intersections.hpp"
typedef K::FT FT;
typedef K::Direction_3 Direction;
//typedef Tree::Intersection_and_primitive_id<Segment>
typedef
boost::optional<Tree::Intersection_and_primitive_id<Segment>::Type>
Segment_intersection;
//AABBTree::AABBTree(vector<array<array<double, 3>, 3>> & _scene){
AABBTree::AABBTree(vector<array<double, 3>> & _points,
vector<array<int, 3>> & _tris,
Vector3d & p0, Vector3d & p1){
vector<Point> points;
for (unsigned long int i=0; i < _points.size(); ++i){
points.push_back(Point(_points[i][0], _points[i][1],
_points[i][2]));
for (unsigned long int i=0; i < _tris.size(); ++i){
array<int, 3> _tri = _tris[i];
triangles.push_back( Triangle(points[_tri[0]], points[_tri[1]],
points[_tri[2]]) );
tree = make_shared<Tree>(triangles.begin(), triangles.end());
Triangle intersected;
Point closestPoint;
double closestDist = numeric_limits<double>::max();
bool intersectionFound = false;
Segment segment_query(Point(p0[0], p0[1], p0[2]), Point(p1[0], p1[1],
p1[2]));
list<Segment_intersection> intersections;
* //uncommenting this line causes the tree to return the correct
triangles when getIntersection is called later
* *//cout << tree->do_intersect(segment_query) << endl;*
Intersection::Intersection(bool _exists, Vector3d _point, Vector3d _normal,
vector<Vector3d> _triangle){
exists = _exists;
point = _point;
normal = _normal;
triangle = _triangle;
bool Intersection::Exists(){
return exists;
Vector3d Intersection::Point(){
return point;
Vector3d Intersection::Normal(){
return normal;
vector<Vector3d> Intersection::Triangle(){
return triangle;
Intersection AABBTree::getIntersection(Vector3d & p0, Vector3d & p1,
Triangle lastIntersected;
if(!_lastIntersected.empty()){
Point l0(_lastIntersected[0][0], _lastIntersected[0][1],
_lastIntersected[0][2]);
Point l1(_lastIntersected[1][0], _lastIntersected[1][1],
_lastIntersected[1][2]);
Point l2(_lastIntersected[2][0], _lastIntersected[2][1],
_lastIntersected[2][2]);
lastIntersected = Triangle(l0, l1, l2);
Point closestPoint;
p1[2]));
tree->all_intersections(segment_query, back_inserter(intersections));
for (auto it = intersections.begin(); it != intersections.end(); ++it){
Primitive pr = (*it)->second;
Triangle tr = pr.datum();
cout << "triangle points:" << endl;
cout << tr.vertex(0) << endl;
cout << tr.vertex(1) << endl;
cout << tr.vertex(2) << endl;
cout << "reference point" << endl;
cout << pr.reference_point() << endl;
if(boost::get<Point>(& (*it)->first )){
intersectionFound = true;
Point p = boost::get<Point>( (*it)->first );
double squaredDist = pow(p.x() - p0[0], 2) + pow(p.y() - p0[1],
2) + pow(p.z() - p0[2], 2);
if(squaredDist < closestDist){
closestDist = squaredDist;
intersected = tr;
closestPoint = p;
cout << "closest point: " << endl;
cout << closestPoint << endl;
//Intersection foo;
if(intersectionFound){
//double pt[3] = {closestPoint.x(), closestPoint.y(),
closestPoint.z()};
Vector3d pt(closestPoint.x(), closestPoint.y(), closestPoint.z());
Plane triPlane = intersected.supporting_plane();
Vector3d triNormal(triPlane.orthogonal_vector().x(),
triPlane.orthogonal_vector().y(),
triPlane.orthogonal_vector().z());
if(triNormal.dot(p0 - pt) < 0){
Plane reversed = triPlane.opposite();
triNormal = Vector3d(reversed.orthogonal_vector().x(),
reversed.orthogonal_vector().y(),
reversed.orthogonal_vector().z());
triNormal.normalize();
//double normal[3] = {triNormal[0], triNormal[1], triNormal[2]};
Point v0 = intersected.vertex(0);
Point v1 = intersected.vertex(1);
Point v2 = intersected.vertex(2);
/*cout << "..." << endl;
cout << v0 << endl;
cout << v1 << endl;
cout << v2 << endl;*/
vector<Vector3d> face;
face.push_back(Vector3d(v0.x(), v0.y(), v0.z()));
face.push_back(Vector3d(v1.x(), v1.y(), v1.z()));
face.push_back(Vector3d(v2.x(), v2.y(), v2.z()));
Intersection intersection(true, pt, triNormal, face);
return intersection;
} else {
Vector3d pt(0.0,0.0,0.0);
Vector3d normal(0.0,0.0,0.0);
face.push_back(Vector3d(0.0, 0.0, 0.0));
Intersection intersection(false, pt, normal, face);
//return foo;
- [cgal-discuss] using cgal AABB tree as class member, myociss, 02/04/2020
- Re: [cgal-discuss] using cgal AABB tree as class member, Mael, 02/04/2020
- Re: [cgal-discuss] using cgal AABB tree as class member, myociss, 02/04/2020
- Re: [cgal-discuss] using cgal AABB tree as class member, Sebastien Loriot (GeometryFactory), 02/06/2020
- Re: [cgal-discuss] using cgal AABB tree as class member, myociss, 02/07/2020
