cgal-discuss - Re: [cgal-discuss] Infinite loop in PMP::corefine_and_compute_union since 4.14.2
  • To:
  • Subject: Re: [cgal-discuss] Infinite loop in PMP::corefine_and_compute_union since 4.14.2
  • Date: Thu, 13 Feb 2020 08:41:33 +1000
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
Issue #4522 opened. Merci bien!
G.
On 12/02/2020 9:55 pm, Sebastien Loriot (GeometryFactory) wrote:
Yes please, I could reproduce the issue and it is a real bug!
As a workaround, note that if you write the output in a new mesh
it will work (the bug is only in the inplace version). I'll fix
it asap.
Thanks,
Sebastien.
On 2/12/20 12:08 PM, Giles Puckett wrote:
Hi Sebastien,
Would you like me to raise an issue on github for this?
G.
On 10/02/2020 8:46 pm, Giles Puckett wrote:
Thanks. Have reproduced the infinite loop with doubles in the OFF file (see my other email for file locations).
G.
On 10/02/2020 7:22 pm, Sebastien Loriot (GeometryFactory) wrote:
Hey,
On 2/7/20 6:46 AM, Giles Puckett wrote:
Hi,
Thanks for the suggestion. Can you post a fragment of such an OFF file so I can see what it looks like?
There is the following undocumented function:
  template <typename P, typename NamedParameters>
  bool write_off(std::ostream& os, const Surface_mesh<P>& sm, const NamedParameters& np)
if you pass CGAL::parameters::vertex_point_map(vpm) as np with vpm
being a map with GMPQ as FT or a custom map that forwards `exact(epec_pt)` it should works.
The fonction CGAL::exact(CGAL::EPECK::Point_3) returns an object
of type CGAL::EPECK::Exact_kernel::Point_3.
It will be hard to change the kernel in the original program, because there are a few steps between the mesh and the OFF file writing. But I should be able to dig through the exact_points property map per vertex and get out the exact coordinates.
What format are the coordinate values in the Exact_predicates_exact_constructions_kernel ? (I confess I'm not very good with C++ especially with all the heavy template usage)
This is a filtered kernel and what is dumped is the "middle" of the double interval surrounding the exact values. Note that those intervals
are not necessarily tight as this is also a Lazy kernel that is trying
to avoid doing exact computation until the point it is the only solution.
Best,
Sebastien.
G.
On 6/02/2020 6:20 pm, Sebastien Loriot (GeometryFactory) wrote:
If the error occurs after several operations, for debugging purpose you can use CGAL::Simple_cartesian<CGAL::Gmpq> as kernel and I think when
writing to OFF you will write the exact rational representation.
Then I think I should be able to load them and reproduce the error.
Note that it will be much slower.
Best,
Sebastien.
PS: don't post output meshes as an attachment to the mailing list as
the file will be large (use gist.github.com or whatever online storage service).
On 2/5/20 10:33 AM, Giles Puckett wrote:
Both meshes return true to does_bound_a_volume and false to does_self_intersect. They do not throw an exception for self-intersections. I can send the OFF files if you like, although they don't produce the error they show the shape of the meshes..
G.
On 5/02/2020 6:23 pm, Sebastien Loriot (GeometryFactory) wrote:
Does one of you mesh has a boundary?
The list of PRs that could have introduced a regression is here:
https://github.com/CGAL/cgal/pulls?utf8=%E2%9C%93&q=is%3Apr+is%3Aclosed+label%3AMerged_in_4.12.2++label%3APkg%3A%3APMP+
I don't see anything suspicious. Is it deterministic?
Best,
Sebastien.
On 2/4/20 11:59 PM, Giles Puckett wrote:
Bonjour,
I have a CAD program that uses PMP to merge meshes. I moved from 4.12 to 5.0 in order to use the default visitor to keep attributes on faces through surface mesh unions. However, some previously working meshes now fail with an infinite loop. The problem also appears on 4.14.2.
The infinite loop is in Corefinement::remove_unused_polylines at face_graph_utils.h, line 1634: (in 5.0)
for(vertex_descriptor v: vertices_kept)
     halfedge_descriptor h = halfedge(v, tm), start=GT::null_halfedge();
     do{
       while ( !is_border(h, tm) || is_border(opposite(h, tm), tm) ) // This while loop never exits
         h = opposite(next(h, tm), tm);
       halfedge_descriptor in = h;
       if (start==GT::null_halfedge())
         start=in;
       else
         if (start==in)
           break;
       while ( is_border(h, tm) )
       set_next(in, opposite(h, tm), tm);
     while(true);//this loop handles non-manifold vertices
One mesh is a simple convex shape, the other is the result of a previous union. All unions are done with exact predicates and constructions in the standard way for consecutive bool ops. Testing for self-intersections before and during the union reveals nothing.
Sadly, I cannot reproduce it in a simple test example program (when writing the meshes to OFF file, precision is lost, and I get self-intersections or an assertion about collinear points). I suspect there may be zero-area triangles produced by the first union.
Three questions:
Have there been any changes in corefinement, PMP or surface meshes between 4.12 and 4.14.2 that might produce this, or any known regressions?
And is there any way I can write the meshes out with sufficient accuracy to submit a simple test case?
Lastly, is there any way I can get the functionality of the example program (corefinement_mesh_union_with_attributes) to work in 4.12?
Thanks for any help and for reading on this far :-)
Giles.
