cgal-discuss - Re: [cgal-discuss] CGAL Is there a way to slice the mesh and check the connectivity?
  • To:
  • Subject: Re: [cgal-discuss] CGAL Is there a way to slice the mesh and check the connectivity?
  • Date: Wed, 12 Feb 2020 06:04:34 -0600 (CST)
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Fail ; spf=Pass
  • Ironport-phdr: 9a23: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
I also noted that in https://doc.cgal.org/latest/Surface_mesh/index.html
there is a description of the half-mesh connectivity:
>The connectivity is also stored in properties, namely the properties named
"v:connectivity", >"h:connectivity", and "f:connectivity". It is quite
similar for the marker of deleted element, where we have >"v:removed",
"e:removed", and "f:removed".
but it is about the connection among the data structure not the
connectivity of the graph.
be open, be creative, be critical
