- To:
- Subject: Re: [cgal-discuss] Fwd: CGAL classification
- Date: Mon, 24 Feb 2020 09:58:29 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23: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
Dear Mr. Jinwei, Le 21/02/2020 à 05:56, Zhang Jinwei a
écrit :
For output configuration file I use:
std::ofstream fconfig(“classifier_config.gz”);
classifier.save_configuration(fconfig);
fconfig.close();
Note that on some OS (Windows for example), you need to specify the
tag std::ios_base::binary so that the binary output is correctly
written. That might be the source of your error here?
However, when I tried to produce and load my own
configuration file by using save_ and load_configuration
function, then I encountered an exception errors which jumps to
the boost serialization library file. I compared the file I
produced with the file in your example, and I found your
configuration file is ascii format while mine is binary format.
So how did you generate the configuration file of the trained
classifier?
You must be mistaken, the configuration files provided with CGAL are
also binary (to be precise: they are compressed archives containing
an ASCII file).
Another question: as shown in the examples, the
cluster and mesh can also be classified by the package. But
there is no example to show how to export them? In which format?
If you are talking about the configuration file, then it's no
different from the point set case, the save_configuration +
load_configuration should work all the same.And how to export the results of cluster and mesh
with the colors and labels?
If your clusters are defined on a CGAL::Point_set_3 (as is done
in the example of the user manual), then you can just propagate
the labels back to the inliers of each cluster and color them
similarly to what is done in the point sets example. For the mesh, if your are using a CGAL::Surface_mesh (as is done in the example of the user manual), then you can also generate a color for each face. The API is slightly different from Point_set: in Point_set, you need to define 3 properties of type unsigned char "r", "g" and "b", whereas for Surface_mesh, you need to define 1 face property of type CGAL::Color "v:color". Then, use CGAL::write_ply to save your mesh to the PLY format: https://doc.cgal.org/latest/Surface_mesh/group__PkgSurface__mesh.html#ga77bbb79d449c981895eedb6c3c23bd14 I hope this helps. Best regards, -- Simon Giraudot, PhD R&D Engineer GeometryFactory - http://geometryfactory.com/ If you could give me help and suggestions, I would
really appreciate it!
Thank you very much! Looking forward to your
reply!
Best regards,
Jinwei
On Wed 19. Feb 2020 at
16:27, Simon Giraudot <>
wrote:
Hello, Sorry you encountered trouble with CGAL Classification. What version of CGAL are you using? Also, can you share a source code + the full error messages? Best regards,
-- Simon Giraudot, PhD R&D Engineer GeometryFactory - http://geometryfactory.com/ Le 18/02/2020 à 19:12, Zhang Jinwei a écrit :
- [cgal-discuss] Fwd: CGAL classification, Zhang Jinwei, 02/18/2020
- Re: [cgal-discuss] Fwd: CGAL classification, Simon Giraudot, 02/19/2020
- Re: [cgal-discuss] Fwd: CGAL classification, Zhang Jinwei, 02/21/2020
- Re: [cgal-discuss] Fwd: CGAL classification, Simon Giraudot, 02/24/2020
- Re: [cgal-discuss] Fwd: CGAL classification, Zhang Jinwei, 02/28/2020
- Re: [cgal-discuss] Fwd: CGAL classification, Simon Giraudot, 02/28/2020
- Re: [cgal-discuss] Fwd: CGAL classification, Zhang Jinwei, 02/29/2020
