- To:
- Subject: Re: [cgal-discuss] Spatial searching - Radius search with Surface_mesh
- Date: Tue, 25 Feb 2020 13:21:27 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23: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
Hello,
Sorry for the late answer.
The problem comes from your line:
CGAL::Fuzzy_sphere<Traits> fz(query, radius, epsilon);
Calling that constructor means that you default construct the traits. With that particular traits class, it will default-construct your vertex-point map and things will go sour.
You should write instead:
Traits traits(vppmap); // possibly factorized at a higher
level because it's also used in the tree
epsilon, traits);
and things will run fine. This works for Polyhedron because the
default constructed vpm accesses the correct data.
I will modify the example so it's more natural to change the
graph type.
Best,
Mael
Hello,
I'm looking for a way to do a radius search with Surface_mesh that returns a list of vertex descriptors.
The following example do what I want with Polyhedron_3:
"https://github.com/CGAL/cgal/blob/releases/CGAL-4.14.2/Spatial_searching/examples/Spatial_searching/searching_polyhedron_vertices_with_fuzzy_sphere.cpp"
I tried to change this example to make it work with Surface_mesh. The code compiles, but there is a runtime error:
terminate called after throwing an instance of
'CGAL::Assertion_exception'
what(): CGAL ERROR: assertion violation!
Expr: parray_ != NULL
File: ~/CGAL-4.14.2/include/CGAL/Surface_mesh/Properties.h
Line: 576
The same error occurs with CGAL-4.14.2 and CGAL-5.0.1.
The source code is attached (radius_search.cpp). The "#if" at line 16 toggles between Polyhedron_3 and Surface_mesh.
What is wrong with Surface_mesh with this code ?
Regards,
- [cgal-discuss] Spatial searching - Radius search with Surface_mesh, Eric Lombardi, 02/12/2020
- Re: [cgal-discuss] Spatial searching - Radius search with Surface_mesh, Mael, 02/25/2020
- Re: [cgal-discuss] Spatial searching - Radius search with Surface_mesh, Eric Lombardi, 02/26/2020
