- To:
- Subject: Re: [cgal-discuss] Spatial searching - Radius search with Surface_mesh
- Date: Wed, 26 Feb 2020 07:34:27 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Thanks a lot for your answer.
Regards,
Eric Lombardi
LIRIS, UMR 5205
Laboratoire d'InfoRmatique en Image et Systèmes d'information
Université Claude Bernard Lyon 1, bâtiment Nautibus
43 boulevard du 11 novembre 1918, 69622 Villeurbanne cedex
Le 25/02/2020 à 13:21, Mael a écrit :
Hello,
Sorry for the late answer.
The problem comes from your line:
/ CGAL::Fuzzy_sphere<Traits> fz(query, radius, epsilon);/
Calling that constructor means that you default construct the traits. With that particular traits class, it will default-construct your vertex-point map and things will go sour.
You should write instead:
/ Traits traits(vppmap); // possibly factorized at a higher level because it's also used in the tree//
// CGAL::Fuzzy_sphere<Traits> fz(query, radius, epsilon, traits);//
and things will run fine. This works for Polyhedron because the default constructed vpm accesses the correct data.
I will modify the example so it's more natural to change the graph type.
Best,
Mael
On 12/02/2020 11:21, Eric Lombardi wrote:
Hello,
I'm looking for a way to do a radius search with Surface_mesh that returns a list of vertex descriptors.
The following example do what I want with Polyhedron_3:
"https://github.com/CGAL/cgal/blob/releases/CGAL-4.14.2/Spatial_searching/examples/Spatial_searching/searching_polyhedron_vertices_with_fuzzy_sphere.cpp"
I tried to change this example to make it work with Surface_mesh. The code compiles, but there is a runtime error:
terminate called after throwing an instance of
'CGAL::Assertion_exception'
what(): CGAL ERROR: assertion violation!
Expr: parray_ != NULL
File: ~/CGAL-4.14.2/include/CGAL/Surface_mesh/Properties.h
Line: 576
The same error occurs with CGAL-4.14.2 and CGAL-5.0.1.
The source code is attached (radius_search.cpp). The "#if" at line 16 toggles between Polyhedron_3 and Surface_mesh.
What is wrong with Surface_mesh with this code ?
Regards,
- [cgal-discuss] Spatial searching - Radius search with Surface_mesh, Eric Lombardi, 02/12/2020
- Re: [cgal-discuss] Spatial searching - Radius search with Surface_mesh, Mael, 02/25/2020
- Re: [cgal-discuss] Spatial searching - Radius search with Surface_mesh, Eric Lombardi, 02/26/2020
