cgal-discuss - Re: [cgal-discuss] mesh_smoothing_method with Ceres.
  • To:
  • Subject: Re: [cgal-discuss] mesh_smoothing_method with Ceres.
  • Date: Thu, 27 Feb 2020 09:40:19 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
The only error I seems to be:
Could NOT find Eigen3 (missing: EIGEN3_INCLUDE_DIR) (Required is at least
Could you check that you gave a valid value to this cmake variable?
Sebastien.
On 2/26/20 9:56 AM, Frank Dz wrote:
Thanks! I found the Ceres_DIR and set it C:/Program Files/Ceres/CMake
Yet, in the Cmake, there is an error:
Selecting Windows SDK version to target Windows 10.0.17763.
Found Boost: C:/local/boost_1_72_0 (found suitable version "1.72.0", minimum
required is "1.48")
Boost include dirs: C:/local/boost_1_72_0
Boost libraries:
Visual Leak Detector (VLD) is not found.
Found Boost: C:/local/boost_1_72_0 (found version "1.72.0")
Examples that use OpenMesh will not be compiled.
version "3.2.0")
ERROR: Intel TBB NOT found! Please define the TBBROOT (or TBB_INSTALL_DIR)
and/or TBB_ARCH_PLATFORM environment variables.
Looked for Threading Building Blocks in C:/Program
Files/Intel/TBB;C:/Program Files (x86)/Intel/TBB
NOTICE: Intel TBB was not found. Sequential code will be used.
CMake Warning (dev) at C:/Program Files/Ceres/CMake/CeresConfig.cmake:209:
Syntax Warning in cmake code at column 40
Argument not separated from preceding token by whitespace.
Call Stack (most recent call first):
CMakeLists.txt:117 (find_package)
This warning is for project developers. Use -Wno-dev to suppress it.
CMake Warning (dev) at C:/Program Files/Ceres/CMake/CeresConfig.cmake:212:
Syntax Warning in cmake code at column 61
CMake Warning (dev) at C:/Program Files/Ceres/CMake/CeresConfig.cmake:267:
CMake Warning (dev) at C:/Program Files/Ceres/CMake/CeresConfig.cmake:299:
Syntax Warning in cmake code at column 44
CMake Warning (dev) at C:/Program Files/Ceres/CMake/CeresConfig.cmake:302:
Syntax Warning in cmake code at column 66
Found installed version of Eigen: C:/Program Files
(x86)/Eigen3/share/eigen3/cmake
Found required Ceres dependency: Eigen version 3.3.7 in C:/Program Files
(x86)/Eigen3/include/eigen3
Found installed version of glog: C:/Program Files (x86)/glog/lib/cmake/glog
Detected glog version: 0.4.0
Found required Ceres dependency: glog
Found installed version of gflags: C:/Program Files
(x86)/gflags/lib/cmake/gflags
Detected gflags version: 2.2.2
Found required Ceres dependency: gflags
Ceres version 1.14.0 detected here: C:/Program Files/Ceres was built with
C++11. Ceres target will add C++11 flags to compile options for targets
using it.
Found Ceres version: 1.14.0 installed in: C:/Program Files/Ceres with
components: [EigenSparse, SparseLinearAlgebraLibrary, LAPACK, SuiteSparse,
SchurSpecializations, C++11, OpenMP, Multithreading]
Configuring done
Besides, I want to make it easy for my configuration of VS15. If it is
possible by linking some libs?
or include something about Ceres.
Best,
Frank
be open, be creative, be critical
