- To: "" <>
- Cc: "" <>
- Subject: Re: [cgal-discuss] mesh_smoothing_method with Ceres.
- Date: Thu, 27 Feb 2020 18:18:04 +0800 (GMT+08:00)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Dear Sebastien,
Thank you very much!
Seems like that I need to set TBB for the example in CGAL-5.0/examples/Polygon_mesh_processing.
Found Boost: C:/local/boost_1_72_0 (found suitable version "1.72.0", minimum required is "1.48")
Boost include dirs: C:/local/boost_1_72_0
Boost libraries:
Visual Leak Detector (VLD) is not found.
Found Boost: C:/local/boost_1_72_0 (found version "1.72.0")
Examples that use OpenMesh will not be compiled.
Found Eigen3: C:/local/eigen-3.3.7 (found suitable version "3.3.7", minimum required is "3.2.0")
ERROR: Intel TBB NOT found! Please define the TBBROOT (or TBB_INSTALL_DIR) and/or TBB_ARCH_PLATFORM environment variables.
Looked for Threading Building Blocks in C:/Program Files/Intel/TBB;C:/Program Files (x86)/Intel/TBB
NOTICE: Intel TBB was not found. Sequential code will be used.
CMake Warning (dev) at C:/Program Files/Ceres/CMake/CeresConfig.cmake:209:
Syntax Warning in cmake code at column 40
Argument not separated from preceding token by whitespace.
Call Stack (most recent call first):
CMakeLists.txt:117 (find_package)
This warning is for project developers. Use -Wno-dev to suppress it.
CMake Warning (dev) at C:/Program Files/Ceres/CMake/CeresConfig.cmake:212:
Syntax Warning in cmake code at column 61
CMake Warning (dev) at C:/Program Files/Ceres/CMake/CeresConfig.cmake:267:
CMake Warning (dev) at C:/Program Files/Ceres/CMake/CeresConfig.cmake:299:
Syntax Warning in cmake code at column 44
CMake Warning (dev) at C:/Program Files/Ceres/CMake/CeresConfig.cmake:302:
Syntax Warning in cmake code at column 66
Found installed version of Eigen: C:/Program Files (x86)/Eigen3/share/eigen3/cmake
Found required Ceres dependency: Eigen version 3.3.7 in C:/Program Files (x86)/Eigen3/include/eigen3
Found installed version of glog: C:/Program Files (x86)/glog/lib/cmake/glog
Detected glog version: 0.4.0
Found required Ceres dependency: glog
Found installed version of gflags: C:/Program Files (x86)/gflags/lib/cmake/gflags
Detected gflags version: 2.2.2
Found required Ceres dependency: gflags
Ceres version 1.14.0 detected here: C:/Program Files/Ceres was built with C++11. Ceres target will add C++11 flags to compile options for targets using it.
Found Ceres version: 1.14.0 installed in: C:/Program Files/Ceres with components: [EigenSparse, SparseLinearAlgebraLibrary, LAPACK, SuiteSparse, SchurSpecializations, C++11, OpenMP, Multithreading]
Configuring done
And as for CMake Warning (dev) at C:/Program Files/Ceres/CMake/CeresConfig.cmake:209: Syntax Warning in cmake code at column 40
I also list CeresConfig.cmake here:
# Ceres Solver - A fast non-linear least squares minimizer
# Copyright 2015 Google Inc. All rights reserved.
# http://ceres-solver.org/
# Redistribution and use in source and binary forms, with or without
# modification, are permitted provided that the following conditions are met:
# * Redistributions of source code must retain the above copyright notice,
# this list of conditions and the following disclaimer.
# * Redistributions in binary form must reproduce the above copyright notice,
# this list of conditions and the following disclaimer in the documentation
# and/or other materials provided with the distribution.
# * Neither the name of Google Inc. nor the names of its contributors may be
# used to endorse or promote products derived from this software without
# specific prior written permission.
# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
# POSSIBILITY OF SUCH DAMAGE.
# Authors: (Pablo Speciale)
# (Alex Stewart)
# Config file for Ceres Solver - Find Ceres & dependencies.
# This file is used by CMake when find_package(Ceres) is invoked and either
# the directory containing this file either is present in CMAKE_MODULE_PATH
# (if Ceres was installed), or exists in the local CMake package registry if
# the Ceres build directory was exported.
# This module defines the following variables:
# Ceres_FOUND / CERES_FOUND: True if Ceres has been successfully
# found. Both variables are set as although
# FindPackage() only references Ceres_FOUND
# in Config mode, given the conventions for
# <package>_FOUND when FindPackage() is
# called in Module mode, users could
# reasonably expect to use CERES_FOUND
# instead.
# CERES_VERSION: Version of Ceres found.
# CERES_INCLUDE_DIRS: Include directories for Ceres and the
# dependencies which appear in the Ceres public
# API and are thus required to use Ceres.
# CERES_LIBRARIES: Libraries for Ceres and all
# dependencies against which Ceres was
# compiled. This will not include any optional
# dependencies that were disabled when Ceres was
# compiled.
# The following variables are also defined for legacy compatibility
# only. Any new code should not use them as they do not conform to
# the standard CMake FindPackage naming conventions.
# CERES_INCLUDES = ${CERES_INCLUDE_DIRS}.
# Called if we failed to find Ceres or any of its required dependencies,
# unsets all public (designed to be used externally) variables and reports
# error message at priority depending upon [REQUIRED/QUIET/<NONE>] argument.
macro(CERES_REPORT_NOT_FOUND REASON_MSG)
# FindPackage() only references Ceres_FOUND, and requires it to be
# explicitly set FALSE to denote not found (not merely undefined).
set(Ceres_FOUND FALSE)
set(CERES_FOUND FALSE)
unset(CERES_INCLUDE_DIRS)
unset(CERES_LIBRARIES)
# Reset the CMake module path to its state when this script was called.
set(CMAKE_MODULE_PATH ${CALLERS_CMAKE_MODULE_PATH})
# Note <package>_FIND_[REQUIRED/QUIETLY] variables defined by
# FindPackage() use the camelcase library name, not uppercase.
if (Ceres_FIND_QUIETLY)
message(STATUS "Failed to find Ceres - " ${REASON_MSG} ${ARGN})
elseif (Ceres_FIND_REQUIRED)
message(FATAL_ERROR "Failed to find Ceres - " ${REASON_MSG} ${ARGN})
else()
# Neither QUIETLY nor REQUIRED, use SEND_ERROR which emits an error
# that prevents generation, but continues configuration.
message(SEND_ERROR "Failed to find Ceres - " ${REASON_MSG} ${ARGN})
endif ()
return()
endmacro(CERES_REPORT_NOT_FOUND)
# ceres_pretty_print_cmake_list( OUTPUT_VAR [item1 [item2 ... ]] )
# Sets ${OUTPUT_VAR} in the caller's scope to a human-readable string
# representation of the list passed as the remaining arguments formed
# as: "[item1, item2, ..., itemN]".
function(ceres_pretty_print_cmake_list OUTPUT_VAR)
string(REPLACE ";" ", " PRETTY_LIST_STRING "[${ARGN}]")
set(${OUTPUT_VAR} "${PRETTY_LIST_STRING}" PARENT_SCOPE)
endfunction()
# The list of (optional) components this version of Ceres was compiled with.
set(CERES_COMPILED_COMPONENTS "EigenSparse;SparseLinearAlgebraLibrary;LAPACK;SuiteSparse;SchurSpecializations;C++11;OpenMP;Multithreading")
# If Ceres was not installed, then by definition it was exported
# from a build directory.
set(CERES_WAS_INSTALLED TRUE)
# Record the state of the CMake module path when this script was
# called so that we can ensure that we leave it in the same state on
# exit as it was on entry, but modify it locally.
set(CALLERS_CMAKE_MODULE_PATH ${CMAKE_MODULE_PATH})
# Get the (current, i.e. installed) directory containing this file.
get_filename_component(CERES_CURRENT_CONFIG_DIR
"${CMAKE_CURRENT_LIST_FILE}" PATH)
if (CERES_WAS_INSTALLED)
# Reset CMake module path to the installation directory of this
# script, thus we will use the FindPackage() scripts shipped with
# Ceres to find Ceres' dependencies, even if the user has equivalently
# named FindPackage() scripts in their project.
set(CMAKE_MODULE_PATH ${CERES_CURRENT_CONFIG_DIR})
# Build the absolute root install directory as a relative path
# (determined when Ceres was configured & built) from the current
# install directory for this this file. This allows for the install
# tree to be relocated, after Ceres was built, outside of CMake.
get_filename_component(CURRENT_ROOT_INSTALL_DIR
${CERES_CURRENT_CONFIG_DIR}/../
ABSOLUTE)
if (NOT EXISTS ${CURRENT_ROOT_INSTALL_DIR})
ceres_report_not_found(
"Ceres install root: ${CURRENT_ROOT_INSTALL_DIR}, "
"determined from relative path from CeresConfig.cmake install location: "
"${CERES_CURRENT_CONFIG_DIR}, does not exist. Either the install "
"directory was deleted, or the install tree was only partially relocated "
"outside of CMake after Ceres was built.")
endif (NOT EXISTS ${CURRENT_ROOT_INSTALL_DIR})
# Set the include directories for Ceres (itself).
set(CERES_INCLUDE_DIR "${CURRENT_ROOT_INSTALL_DIR}/include")
if (NOT EXISTS ${CERES_INCLUDE_DIR}/ceres/ceres.h)
"${CERES_CURRENT_CONFIG_DIR}, does not contain Ceres headers. "
"Either the install directory was deleted, or the install tree was only "
"partially relocated outside of CMake after Ceres was built.")
endif (NOT EXISTS ${CERES_INCLUDE_DIR}/ceres/ceres.h)
list(APPEND CERES_INCLUDE_DIRS ${CERES_INCLUDE_DIR})
else(CERES_WAS_INSTALLED)
# Ceres was exported from the build tree.
set(CERES_EXPORTED_BUILD_DIR ${CERES_CURRENT_CONFIG_DIR})
get_filename_component(CERES_EXPORTED_SOURCE_DIR
${CERES_EXPORTED_BUILD_DIR}/../
ABSOLUTE)
if (NOT EXISTS ${CERES_EXPORTED_SOURCE_DIR})
"Ceres exported source directory: ${CERES_EXPORTED_SOURCE_DIR}, "
"determined from relative path from CeresConfig.cmake exported build "
"directory: ${CERES_EXPORTED_BUILD_DIR} does not exist.")
endif()
# Reset CMake module path to the cmake directory in the Ceres source
# tree which was exported, thus we will use the FindPackage() scripts shipped
# with Ceres to find Ceres' dependencies, even if the user has equivalently
set(CMAKE_MODULE_PATH ${CERES_EXPORTED_SOURCE_DIR}/cmake)
set(CERES_INCLUDE_DIR "${CERES_EXPORTED_SOURCE_DIR}/include")
"directory: ${CERES_EXPORTED_BUILD_DIR}, does not contain Ceres headers.")
# Append the path to the configured config.h in the exported build directory
# to the Ceres include directories.
set(CERES_CONFIG_FILE
${CERES_EXPORTED_BUILD_DIR}/config/ceres/internal/config.h)
if (NOT EXISTS ${CERES_CONFIG_FILE})
"Ceres exported build directory: ${CERES_EXPORTED_BUILD_DIR}, "
"does not contain required configured Ceres config.h, it is not here: "
"${CERES_CONFIG_FILE}.")
endif (NOT EXISTS ${CERES_CONFIG_FILE})
list(APPEND CERES_INCLUDE_DIRS ${CERES_EXPORTED_BUILD_DIR}/config)
endif(CERES_WAS_INSTALLED)
# Set the version.
set(CERES_VERSION 1.14.0 )
# Eigen.
# Flag set during configuration and build of Ceres.
set(CERES_EIGEN_VERSION 3.3.7)
set(EIGEN_WAS_BUILT_WITH_CMAKE TRUE)
# Append the locations of Eigen when Ceres was built to the search path hints.
if (EIGEN_WAS_BUILT_WITH_CMAKE)
set(Eigen3_DIR C:/Program Files (x86)/Eigen3/share/eigen3/cmake)
set(EIGEN_PREFER_EXPORTED_EIGEN_CMAKE_CONFIGURATION TRUE)
else()
list(APPEND EIGEN_INCLUDE_DIR_HINTS C:/Program Files (x86)/Eigen3/include/eigen3)
endif()
# Search quietly to control the timing of the error message if not found. The
# search should be for an exact match, but for usability reasons do a soft
# match and reject with an explanation below.
find_package(Eigen ${CERES_EIGEN_VERSION} QUIET)
if (EIGEN_FOUND)
if (NOT EIGEN_VERSION VERSION_EQUAL CERES_EIGEN_VERSION)
# CMake's VERSION check in FIND_PACKAGE() will accept any version >= the
# specified version. However, only version = is supported. Improve
# usability by explaining why we don't accept non-exact version matching.
ceres_report_not_found("Found Eigen dependency, but the version of Eigen "
"found (${EIGEN_VERSION}) does not exactly match the version of Eigen "
"Ceres was compiled with (${CERES_EIGEN_VERSION}). This can cause subtle "
"bugs by triggering violations of the One Definition Rule. See the "
"Wikipedia article http://en.wikipedia.org/wiki/One_Definition_Rule "
"for more details")
endif ()
message(STATUS "Found required Ceres dependency: "
"Eigen version ${CERES_EIGEN_VERSION} in ${EIGEN_INCLUDE_DIRS}")
else (EIGEN_FOUND)
ceres_report_not_found("Missing required Ceres "
"dependency: Eigen version ${CERES_EIGEN_VERSION}, please set "
"EIGEN_INCLUDE_DIR.")
endif (EIGEN_FOUND)
list(APPEND CERES_INCLUDE_DIRS ${EIGEN_INCLUDE_DIRS})
# Glog.
set(CERES_USES_MINIGLOG OFF)
set(CERES_USES_GFLAGS ON)
if (CERES_USES_MINIGLOG)
set(MINIGLOG_INCLUDE_DIR ${CERES_INCLUDE_DIR}/ceres/internal/miniglog)
if (NOT CERES_WAS_INSTALLED)
# When Ceres was exported from the build tree, the miniglog headers
# will be in Ceres internal source directory, not in the public headers
# directory (they are copied with the public headers when installed).
${CERES_EXPORTED_SOURCE_DIR}/internal/ceres/miniglog)
endif()
if (NOT EXISTS ${MINIGLOG_INCLUDE_DIR})
"Failed to find miniglog headers in expected include directory: "
"${MINIGLOG_INCLUDE_DIR}, but Ceres was compiled with MINIGLOG enabled "
"(in place of glog).")
endif (NOT EXISTS ${MINIGLOG_INCLUDE_DIR})
list(APPEND CERES_INCLUDE_DIRS ${MINIGLOG_INCLUDE_DIR})
# Output message at standard log level (not the lower STATUS) so that
# the message is output in GUI during configuration to warn user.
message("-- Found Ceres compiled with miniglog substitute "
"for glog, beware this will likely cause problems if glog is later linked.")
else (CERES_USES_MINIGLOG)
# Append the locations of glog when Ceres was built to the search path hints.
set(GLOG_WAS_BUILT_WITH_CMAKE 1)
if (GLOG_WAS_BUILT_WITH_CMAKE)
set(glog_DIR C:/Program Files (x86)/glog/lib/cmake/glog)
set(GLOG_PREFER_EXPORTED_GLOG_CMAKE_CONFIGURATION TRUE)
else()
list(APPEND GLOG_INCLUDE_DIR_HINTS )
get_filename_component(CERES_BUILD_GLOG_LIBRARY_DIR glog::glog PATH)
list(APPEND GLOG_LIBRARY_DIR_HINTS ${CERES_BUILD_GLOG_LIBRARY_DIR})
endif()
# Search quietly s/t we control the timing of the error message if not found.
find_package(Glog QUIET)
if (GLOG_FOUND)
message(STATUS "Found required Ceres dependency: glog")
else (GLOG_FOUND)
"dependency: glog. Searched using GLOG_INCLUDE_DIR_HINTS: "
"${GLOG_INCLUDE_DIR_HINTS} and glog_DIR: ${glog_DIR}.")
endif (GLOG_FOUND)
list(APPEND CERES_INCLUDE_DIRS ${GLOG_INCLUDE_DIRS})
# gflags is only a public dependency of Ceres via glog, thus is not required
# if Ceres was built with MINIGLOG.
if (CERES_USES_GFLAGS)
# If gflags was found as an imported CMake target, we need to call
# find_packge(Gflags) again here, as imported CMake targets are not
# re-exported. Without this, the 'gflags-shared' target name which is
# present in CERES_LIBRARIES in this case would not be defined, and so
# CMake will assume it is a library name (which it is not) and fail to link.
# Append the locations of gflags when Ceres was built to the search path
# hints.
set(GFLAGS_WAS_BUILT_WITH_CMAKE 1)
if (GFLAGS_WAS_BUILT_WITH_CMAKE)
set(gflags_DIR C:/Program Files (x86)/gflags/lib/cmake/gflags)
set(GFLAGS_PREFER_EXPORTED_GFLAGS_CMAKE_CONFIGURATION TRUE)
else()
list(APPEND GFLAGS_INCLUDE_DIR_HINTS C:/Program Files (x86)/gflags/include)
get_filename_component(CERES_BUILD_GFLAGS_LIBRARY_DIR gflags_shared PATH)
list(APPEND GFLAGS_LIBRARY_DIR_HINTS ${CERES_BUILD_GFLAGS_LIBRARY_DIR})
endif()
find_package(Gflags QUIET)
if (GFLAGS_FOUND)
message(STATUS "Found required Ceres dependency: gflags")
else()
"dependency: gflags. Searched using GFLAGS_INCLUDE_DIR_HINTS: "
"${GFLAGS_INCLUDE_DIR_HINTS} and gflags_DIR: ${gflags_DIR}.")
endif()
list(APPEND CERES_INCLUDE_DIRS ${GFLAGS_INCLUDE_DIR_HINTS})
endif()
endif (CERES_USES_MINIGLOG)
# Import exported Ceres targets, if they have not already been imported.
if (NOT TARGET ceres AND NOT Ceres_BINARY_DIR)
include(${CERES_CURRENT_CONFIG_DIR}/CeresTargets.cmake)
endif (NOT TARGET ceres AND NOT Ceres_BINARY_DIR)
# Set the expected XX_LIBRARIES variable for FindPackage().
set(CERES_LIBRARIES ceres)
# Make user aware of any compile flags that will be added to their targets
# which use Ceres (i.e. flags exported in the Ceres target). Only CMake
# versions >= 2.8.12 support target_compile_options/features().
if (CERES_COMPILED_COMPONENTS MATCHES ".*C\\+\\+11.*") # Search for C++11.
set(CERES_WAS_COMPILED_WITH_CXX11 TRUE)
endif()
if (TARGET ${CERES_LIBRARIES} AND
CERES_WAS_COMPILED_WITH_CXX11 AND
NOT CMAKE_VERSION VERSION_LESS "2.8.12")
set(CERES_LOCATION "${CURRENT_ROOT_INSTALL_DIR}")
else()
set(CERES_LOCATION "${CERES_EXPORTED_BUILD_DIR}")
endif()
message(STATUS "Ceres version ${CERES_VERSION} detected here: "
"${CERES_LOCATION} was built with C++11. Ceres "
"target will add C++11 flags to compile options for "
"targets using it.")
endif()
# Set legacy include directories variable for backwards compatibility.
set(CERES_INCLUDES ${CERES_INCLUDE_DIRS})
# Reset CMake module path to its state when this script was called.
# Build the detected Ceres version string to correctly capture whether it
# was installed, or exported.
ceres_pretty_print_cmake_list(CERES_COMPILED_COMPONENTS_STRING
${CERES_COMPILED_COMPONENTS})
set(CERES_DETECTED_VERSION_STRING "Ceres version: ${CERES_VERSION} "
"installed in: ${CURRENT_ROOT_INSTALL_DIR} with components: "
"${CERES_COMPILED_COMPONENTS_STRING}")
else (CERES_WAS_INSTALLED)
"exported from build directory: ${CERES_EXPORTED_BUILD_DIR} with "
"components: ${CERES_COMPILED_COMPONENTS_STRING}")
endif()
# If the user called this script through find_package() whilst specifying
# particular Ceres components that should be found via:
# find_package(Ceres COMPONENTS XXX YYY), check the requested components against
# those with which Ceres was compiled. In this case, we should only report
# Ceres as found if all the requested components have been found.
if (Ceres_FIND_COMPONENTS)
foreach (REQUESTED_COMPONENT ${Ceres_FIND_COMPONENTS})
list(FIND CERES_COMPILED_COMPONENTS ${REQUESTED_COMPONENT} HAVE_REQUESTED_COMPONENT)
# list(FIND ..) returns -1 if the element was not in the list, but CMake
# interprets if (VAR) to be true if VAR is any non-zero number, even
# negative ones, hence we have to explicitly check for >= 0.
if (HAVE_REQUESTED_COMPONENT EQUAL -1)
# Check for the presence of all requested components before reporting
# not found, such that we report all of the missing components rather
# than just the first.
list(APPEND MISSING_CERES_COMPONENTS ${REQUESTED_COMPONENT})
endif()
endforeach()
if (MISSING_CERES_COMPONENTS)
ceres_pretty_print_cmake_list(REQUESTED_CERES_COMPONENTS_STRING
ceres_pretty_print_cmake_list(MISSING_CERES_COMPONENTS_STRING
${MISSING_CERES_COMPONENTS})
ceres_report_not_found("Missing requested Ceres components: "
"${MISSING_CERES_COMPONENTS_STRING} (components requested: "
"${REQUESTED_CERES_COMPONENTS_STRING}). Detected "
"${CERES_DETECTED_VERSION_STRING}.")
endif()
endif()
# As we use CERES_REPORT_NOT_FOUND() to abort, if we reach this point we have
# found Ceres and all required dependencies.
message(STATUS "Found " ${CERES_DETECTED_VERSION_STRING})
# Set CERES_FOUND to be equivalent to Ceres_FOUND, which is set to
# TRUE by FindPackage() if this file is found and run, and after which
# Ceres_FOUND is not (explicitly, i.e. undefined does not count) set
# to FALSE.
set(CERES_FOUND TRUE)
The only error I seems to be:
Could NOT find Eigen3 (missing: EIGEN3_INCLUDE_DIR) (Required is at least
Could you check that you gave a valid value to this cmake variable?
Sebastien.
On 2/26/20 9:56 AM, Frank Dz wrote:
Thanks! I found the Ceres_DIR and set it C:/Program Files/Ceres/CMake
Yet, in the Cmake, there is an error:
Selecting Windows SDK version to target Windows 10.0.17763.
required is "1.48")
Boost libraries:
version "3.2.0")
using it.
Configuring done
Besides, I want to make it easy for my configuration of VS15. If it is
possible by linking some libs?
or include something about Ceres.
Best,
Frank
be open, be creative, be critical
- [cgal-discuss] mesh_smoothing_method with Ceres., Frank Dz, 02/26/2020
- Re: [cgal-discuss] mesh_smoothing_method with Ceres., Sebastien Loriot (GeometryFactory), 02/26/2020
- Re: [cgal-discuss] mesh_smoothing_method with Ceres., Frank Dz, 02/26/2020
- Re: [cgal-discuss] mesh_smoothing_method with Ceres., Sebastien Loriot (GeometryFactory), 02/27/2020
- Re: [cgal-discuss] mesh_smoothing_method with Ceres., Zhiyang Dou, 02/27/2020
