- To:
- Subject: Re: [cgal-discuss] Visualize non-2-manifold object
- Date: Thu, 28 May 2020 07:51:42 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23:y76zdRwEtDGI+HXXCy+O+j09IxM/srCxBDY+r6Qd0uoVL/ad9pjvdHbS+e9qxAeQG9mCtrQd0bed4/CocFdDyK7JiGoFfp1IWk1NouQttCtkPvS4D1bmJuXhdS0wEZcKflZk+3amLRodQ56mNBXdrXKo8DEdBAj0OxZrKeTpAI7SiNm82/yv95HJbAhEmTqwbalvIBmorQjducobjIh/Iast1xXFpWdFdf5Lzm1yP1KTmBj85sa0/JF99ilbpuws+c1dX6jkZqo0VbNXAigoPGAz/83rqALMTRCT6XsGU2UZiQRHDg7Y5xznRJjxsy/6tu1g2CmGOMD9UL45VSi+46ptVRTljjoMOTwk/2HNksF+kbxVoByhqRJ8zYDbbo6aO/hica3SZt4aWWhMU9xNWyBdDI6xbY0CBPcBM+ZCqIn9okMDoRWjCwayH+zg0CRIhmP33aIk1eQqDAfI3As6H9IPt3TUsMj+OKMTX++ry6nIyCvMb+9M2Tb96IbHaAwuoe2LXbJqccvdzEcjHB7Cg1WLrYzlOCmV1uUKs2iH9eZgUOavhnUoqwF0uDevx8MshpPViYISz1DJ7CN0y5s6KtOkUkB0e8KkEIdOuCGAMYt7Wt0uT3xstSom17ELpJC1cTUFxpkkxBPSduKKf5aM7x/iVuucPDl2iW9rdby/hxu8/lasxvPzW8SqzltEoCtIn9fKu3sQ2RLT7c2HReF8/kenwTuP2B7c6uZBIU8qiarbMZ4gwrAqmZUPrUTDGTX2mUXsgKCKcUUk//Ck6+L9bbr9vZCcM5F7hhviPaQpn8yyB/kzPAsWX2WD5+iwyLnu8Vf6TbhKlPE6jLfVvI3AKckUpKO1GxFZ3Zw/5xqiCjqpzsgUkmMCIV5bZB6Lko3kNl/UL/zmEfuyhk+jnCpoyvzaO7DuGI7CI3rMnbrkfLtw601RxBY2wN9B6J9YFL8MLfTuUUHrrtPYFAU2MwmszubnFtp90oQeVHqKAqCDMaPStUaE5+w1I+WRfYMVtjnwJvo/6/7hin85nlAdfa230pcNdH+4GfFmL12YYXrqnNgBDX8HshQiQOHuklGPUj5ea2ysU64i+z03Eo2rAIXbSoComrOB3SO7HpNMZmBBD1CBCWzod4GDW/cWaSKSJdNhniYBVbilUIIh2hSuuxX7y7pjNObb5ioYtZf72Nhv++LTjQ0y9SBzD8mFz26NQHt7nmcRSzAr3aB/ulByykqY0ahjmPFYDtxS5/ZRUgggL5Lczup6C8rzWg3bZNuJRkymEZ2aBmQ6Qds1htMPeE1gAM6KjxbZ3iPsDaVGuaaMAcl+ya/W1mPtJst7g1LBzqgmkxFmbcZIMGC6nL9R/gPPAJTY0g/Rw72ucr4d2zKL8WOrwm+HvUUeWwl1B/aWFUsDb1fb+IyqrnjJSKWjXOx+bllxjPWaI64PUeXHyE1cTa66atvbamO13Wy3AETQn+LeXM/RY2wYmR7lJg0BmgEX82yBMFFnVCikqmPaSjdpEAC2Oh6+waxFsHq+C3QM4USKYklmjefn/xcUgbmDUapW0O5b/igmrDpwERC22NeEU9c=
Are you looking for that example?
https://cgal.geometryfactory.com/CGAL/doc/master/Nef_3/Nef_3_2draw_nef_3_8cpp-example.html
Best,
Sebastien
On 5/28/20 3:11 AM, AliiAsgharii ( via cgal-discuss Mailing List) wrote:
Hello CGAL team,
Is there any way to read and draw non-2-manifold objects using CGAL?
I could see in the master version of CGAL, drawing nef polyhedron would be
possible.
Does it mean by using that we would be able to draw this sort of objects?
and if yes, when would be able to use this facility as the examples are not
accessible yet?
Best regards,
Ali
- [cgal-discuss] Visualize non-2-manifold object, AliiAsgharii, 05/28/2020
- Re: [cgal-discuss] Visualize non-2-manifold object, Sebastien Loriot (GeometryFactory), 05/28/2020
- Re: [cgal-discuss] Visualize non-2-manifold object, AliiAsgharii, 05/28/2020
- Re: [cgal-discuss] Visualize non-2-manifold object, Andreas Fabri, 05/28/2020
- Re: [cgal-discuss] Visualize non-2-manifold object, AliiAsgharii, 05/31/2020
