- To:
- Subject: Re: [cgal-discuss] Visualize non-2-manifold object
- Date: Thu, 28 May 2020 01:38:12 -0500 (CDT)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
- Ironport-phdr: 9a23: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
I already tried several times to compile this example. But I receive this
error:
"cannot open include file: 'CGAL/draw_nef_3.h': No such file or directory
I updated the Nef_3 folder, Shall I need to update CGAL to use this?
Best regards,
Ali
- [cgal-discuss] Visualize non-2-manifold object, AliiAsgharii, 05/28/2020
- Re: [cgal-discuss] Visualize non-2-manifold object, Sebastien Loriot (GeometryFactory), 05/28/2020
- Re: [cgal-discuss] Visualize non-2-manifold object, AliiAsgharii, 05/28/2020
- Re: [cgal-discuss] Visualize non-2-manifold object, Andreas Fabri, 05/28/2020
- Re: [cgal-discuss] Visualize non-2-manifold object, AliiAsgharii, 05/31/2020
